Thank you, @sihui!
Further investigation has led me to find that there are 4 main approaches;
- Do everything in PaperUI, and edit the JSON file if tweaks are required
@hmerkHans-Jörg MerkFoundation member
…If you need to edit a thing, you still can do this outside PaperUI, as the JSON storage files are human readable and editable.
- Use PaperUI/HABmin for discovery, and things configuration, use .items and .rules for the rest. Some people copy/paste item info from PaperUI to build .item files
michael_sutter
I’ve grouped my rules and items on files.
Items mainly targeting to bindings and rules targeting types (light, shutter, and heating…)
The fully manual approach as you have helpfully referenced above
Use Home Builder to define sitemap and items
I am currently leaning to #1, and will see if that is viable.
