i finally found the time to migrate my oH 1.8.3 installation to the latest oH 2 version.
I used the latest openhabian image and choosed the expert Setup.
I already changed the password for all users and they´re working fine.
I´m able to connect to some of the predefined SMB shares like the Config folder.
But i´m not able to connect to the share folder [/srv]…
As the user openhabian is working to connect to the Conf share, i don´t think there´s a problem with the user or password.
I already checked the smb.conf and file permissions, but there is no difference.
I also tried using multiple systems, OS and VMs…
smb.conf
[global]
bind interfaces only = Yes
interfaces = eth0
log file = /var/log/samba/log.%m
max log size = 1000
syslog = 0
map to guest = Bad User
obey pam restrictions = Yes
pam password change = Yes
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
passwd program = /usr/bin/passwd %u
security = USER
server role = standalone server
unix password sync = Yes
dns proxy = No
idmap config * : backend = tdb
invalid users = root
[openHAB Share]
comment = openHAB2 combined folders
path = /srv
delete veto files = Yes
veto files = /Thumbs.db/.DS_Store/._.DS_Store/.apdisk/._*/
create mask = 0777
directory mask = 0777
read only = No
valid users = opanhabian
[openHAB Conf]
comment = openHAB2 site configuration
path = /etc/openhab2
create mask = 0777
read only = No
valid users = openhabian
The only difference is the “+” behind the openhab2 folder in /etc.
But i didn´t found any information what this + means and if it has something to do with my problem.
Any ideas how to fix this problem and get an connection to the /srv share?
What´s the difference now?
It´s an standard installation from the latest openhabian image and i didn´t changed anything except the password through the openhabian config.
.71 is an Windows 10 VMware
MacPro is my Mac OSX workstation
[00:53:32] openhabian@HER-openHAB2:/var/log/samba$ tailf log.192.168.2.71
^C
[00:55:11] openhabian@HER-openHAB2:/var/log/samba$ tailf log.her-macpro
[2018/07/14 07:26:16.318475, 0] ../source3/smbd/smb2_server.c:707(smb2_validate_message_id)
smb2_validate_message_id: client used more credits than granted, mid 6, charge 1, credits_granted 0, seqnum low/range: 6/0
[2018/07/14 13:57:07.136263, 0] ../source3/param/loadparm.c:2973(check_usershare_stat)
check_usershare_stat: file /var/lib/samba/usershares/ owned by uid 0 is not a regular file
[2018/07/14 13:57:20.814844, 0] ../source3/smbd/service.c:793(make_connection_snum)
'/etc/default/openhab2' is not a directory, when connecting to [openHAB Service]
[2018/07/14 13:57:20.819079, 0] ../source3/smbd/service.c:793(make_connection_snum)
[2018/07/14 13:57:27.683719, 0] ../source3/param/loadparm.c:2973(check_usershare_stat)
[2018/07/15 00:55:49.385969, 0] ../source3/param/loadparm.c:2973(check_usershare_stat)
^C
[00:56:00] openhabian@HER-openHAB2:/var/log/samba$ tailf log.smbd
[2018/07/12 19:07:59.044253, 0] ../lib/util/become_daemon.c:124(daemon_ready)
STATUS=daemon 'smbd' finished starting up and ready to serve connections
[2018/07/12 19:09:50.221978, 0] ../lib/util/become_daemon.c:124(daemon_ready)
[2018/07/12 19:14:48.270923, 0] ../lib/util/become_daemon.c:124(daemon_ready)
[2018/07/12 19:22:16.845648, 0] ../lib/util/become_daemon.c:124(daemon_ready)
[2018/07/14 22:22:41.791811, 0] ../lib/util/become_daemon.c:124(daemon_ready)
^C
[00:56:32] openhabian@HER-openHAB2:/var/log/samba$ tailf log.
^C
[00:56:47] openhabian@HER-openHAB2:/var/log/samba$ tailf log.nmbd
This response was from IP 192.168.2.8, reporting an IP address of 192.168.2.8.
[2018/07/15 00:44:36.264031, 0] ../source3/nmbd/nmbd_namequery.c:109(query_name_response)
query_name_response: Multiple (2) responses received for a query on subnet 192.168.2.11 for name WORKGROUP<1d>.
[2018/07/15 00:49:49.302904, 0] ../source3/nmbd/nmbd_namequery.c:109(query_name_response)
[2018/07/15 00:54:52.309097, 0] ../source3/nmbd/nmbd_namequery.c:109(query_name_response)
^C
No ideas why the /srv share that comes with openhabian isn´t working?
That is something that is part of the image and not a thing that users implement.
