[SOLVED] Cannot access OpenHAB after update to 2.4
I’ running OpenHAB on a Raspi, and after the update with apt-get, I cannot reach it any longer.
service openhab2 status
shows the server running, and an attempt to connect to http://:8080 returns a Jetty error message (“HTTP ERROR 404//Problem accessing /start/index. Reason://Not Found”). This shows that the server is basically running.
But when I try to connect to port 9001, the connection is refused.
Next, the log files will be created, but they remain empty (length 0 bytes).
I tried the stop, start, restart OpenHAB, and, of course, tried also to reboot the machine, more than once.
Any ideas?
Have you tried a reboot since upgrading?
sudo systemctl stop openhab2
sudo reboot
Jepp, I also tried to stop, start, restart OpenHAB, and I also tried to reboot the machine.
I updated my question AFTER the comment from @H102, but I tried these basic thing BEFORE I issued my post. Nevertheless, as I did not mention it, @H102’s question was perfectly valid …
With the 2.4 upgrade a clean cache is built in but it may be worth trying it via openhab-cli.
sudo openhab-cli clean-cache
sudo systemctl start openhab2
Stopping the OpenHAB server
sudo service openhab2 stop
cleaning up the cache
and then restarting the server again
sudo service openhab2 start
finally did the job.
sudo service <_service_> <_command_>
is equivalent to
sudo systemctl <_command_> <_service_>
as suggested by @H102 – at least on my Raspi …
