openHAB version: openhab-distro, commit c4a1d03, checked out today.
Hi, I’ve been trying to start with binding development via Eclipse.
For this I’ve followed the Eclipse IDE guide.
I’m able to start OpenHAB with the run OSGi button from the app.bndrun file.
However I’m not able to add a binding to this setup.
This is what I’ve done:
I’ve added the astro binding to the pom file:
Now when I start OpenHAB via the run OSGi button and go to settings->bindings I’d expect to see the Astro binding there. However does not seem to be available:
You’re doing nothing wrong. In the ide app the bindings don’t show up in the binding list. But you should be able to add new things, if you go to the things page and click + you should be able to add astro things.
I don’t seem to be able to reproduce it. That is it looks like the first time i add it, and press resolve, save and start it doesn’t show up. But when I repeat this step it does show up. I haven’t the latest version of the distro so this might explain, but maybe not. If you try another binding do you see the same?
