Cannot add Item with key, The specified name of the item is not valid [WARN ]
Hi all,
I recently managed to upgrade from 3.4.4 to 4.0.1 thanks to many usefull posts on this forum and all seems to work quite well. During this process I noticed messages in the log during startup like the one below. There’s a bunch of other ones for different items, they all come from a binding I used to use, either weconnect or connectedcar. I do not have this binding installed anymore and in karaf I cannot find any trace with openhab:links list, openhab:items list or openhab:links orphan list. This doesn’t seem to have anything to do with the upgrade, but still I would like to get rid of this. Anybody as an idea to troubleshoot it?
22:40:54.816 [WARN ] [core.common.registry.AbstractRegistry] - Cannot add "SwitchItem" with key "VWXXXXXXXXXXXXXX_statusAllTiresOK": The specified name of the item 'XXXXXXXXXXXXXX_statusAllTiresOK' is not valid!
java.lang.IllegalArgumentException: The specified name of the item 'VWXXXXXXXXXXXXXX_statusAllTiresOK' is not valid!
	at org.openhab.core.items.ItemUtil.assertValidItemName(ItemUtil.java:79) ~[?:?]
	at org.openhab.core.internal.items.ItemRegistryImpl.initializeItem(ItemRegistryImpl.java:192) ~[?:?]
	at org.openhab.core.internal.items.ItemRegistryImpl.onAddElement(ItemRegistryImpl.java:242) ~[?:?]
	at org.openhab.core.internal.items.ItemRegistryImpl.onAddElement(ItemRegistryImpl.java:1) ~[?:?]
	at org.openhab.core.common.registry.AbstractRegistry.added(AbstractRegistry.java:200) ~[?:?]
	at org.openhab.core.common.registry.AbstractRegistry.addProvider(AbstractRegistry.java:433) ~[?:?]
	at org.openhab.core.internal.items.ItemRegistryImpl.addProvider(ItemRegistryImpl.java:404) ~[?:?]
	at org.openhab.core.common.registry.AbstractRegistry$ProviderTracker.addingService(AbstractRegistry.java:149) ~[?:?]
	at org.openhab.core.common.registry.AbstractRegistry$ProviderTracker.addingService(AbstractRegistry.java:1) ~[?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:943) ~[osgi.core-8.0.0.jar:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:871) ~[osgi.core-8.0.0.jar:?]
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[osgi.core-8.0.0.jar:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[osgi.core-8.0.0.jar:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:903) ~[osgi.core-8.0.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:123) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:961) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:937) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:874) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:141) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:262) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:500) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:929) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:915) ~[?:?]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:984) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:752) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1274) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1225) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1232) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1152) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:959) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:895) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1184) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:116) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:437) ~[?:?]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:671) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:310) ~[?:?]
	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:593) ~[?:?]
	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:74) ~[?:?]
	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:460) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488) ~[osgi.core-8.0.0.jar:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:420) ~[osgi.core-8.0.0.jar:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[osgi.core-8.0.0.jar:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450) ~[osgi.core-8.0.0.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:949) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:229) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.Module.start(Module.java:486) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:513) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer.start(ModuleContainer.java:888) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer.applyDelta(ModuleContainer.java:879) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer.resolveAndApply(ModuleContainer.java:560) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:503) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer.refresh(ModuleContainer.java:1139) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1520) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) ~[org.eclipse.osgi-3.18.0.jar:?]
If you are using .items files, search through those to make sure that Item doesn’t exist there.
Then search through all the files in $OH_USERDATA/jsodb for any mention of that Item.
Note, if for some reason you have a backup of a file that no longer exists in the main jsondb folder, the backup file will be used.
If you know what you are doing, go ahead and remove the entry that is referencing that Item. If not, come back with what you’ve found in which files.
Hi Rich,
Thanx for the pointer. I have no .items files. And ouch, I found 267 references in 20 files. 16 of these files are located in ./jsondb/backup/. Hand-editing the files will probably keep me busy for a rainy sunday afternoon. Or could i just delete the files in ./jsondb/backup/ ?
Possibly as long as you have the equivalent file in the main folder. If you’ve deleted the file in the main folder, the most recent file in the backup is used. So be careful.
