Hello guys!
Platform information:
- Hardware: Acer Aspire, 2Ghz CPU, 3GB RAM
- OS: Ubuntu Server 18.10
- Java Runtime Environment: 8
- openHAB version: 2.4 SnapShot #1423
Issue of the topic: i’m binding the Philips hue system and it never ends. Although after that when I go to the bindings menu, i can see it, but doesn’t seem to be finished. I mean i cannot edit its properties, seems like a manually added binding. Btw i can uninstall it, it appers even in the logs. When i install it it doesn’t appear.
If logs where generated please post these here using code fences:
20:34:42.873 [INFO ] [bpanel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
20:34:43.452 [INFO ] [mebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
20:35:03.449 [INFO ] [rthome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
20:35:07.154 [INFO ] [i.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.8.100:8080
20:35:07.156 [INFO ] [i.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.8.100:8443
20:35:07.962 [INFO ] [marthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
20:37:58.876 [INFO ] [i.dashboard.internal.DashboardService] - Stopped Dashboard
20:38:02.922 [INFO ] [mebuilder.internal.HomeBuilderServlet] - Stopped Home Builder
20:38:02.951 [INFO ] [bpanel.internal.HABPanelDashboardTile] - Stopped HABPanel
20:38:02.967 [INFO ] [marthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
20:38:03.104 [INFO ] [.basic.internal.servlet.WebAppServlet] - Stopped Basic UI
20:38:05.800 [INFO ] [i.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.8.100:8080
20:38:05.804 [INFO ] [i.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.8.100:8443
20:38:05.847 [INFO ] [mebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
20:38:05.904 [INFO ] [bpanel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
20:38:05.939 [INFO ] [marthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
20:38:08.940 [INFO ] [.core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-binding-hue'
20:38:55.361 [INFO ] [i.dashboard.internal.DashboardService] - Stopped Dashboard
20:38:59.403 [INFO ] [mebuilder.internal.HomeBuilderServlet] - Stopped Home Builder
20:38:59.437 [INFO ] [bpanel.internal.HABPanelDashboardTile] - Stopped HABPanel
20:38:59.455 [INFO ] [marthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
20:38:59.523 [INFO ] [.basic.internal.servlet.WebAppServlet] - Stopped Basic UI
20:39:02.061 [INFO ] [i.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.8.100:8080
20:39:02.065 [INFO ] [i.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.8.100:8443
20:39:02.106 [INFO ] [mebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
20:39:02.157 [INFO ] [bpanel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
20:39:02.184 [INFO ] [marthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
I upgraded the Ubuntu, restarted the server / service few times. Still nothing. Please help!
Regards
Peter
