I am creating a rule to keep some lights on for a period of time.
I am trying to compare timeInMillis from two different periods. These are Long Types
But for some reason i cannot substract or even compare two epoch times. The result is:
2018-12-01 12:56:53.934 [INFO ] [rthome.model.script.front_door.rules] - Triggered wakeup
2018-12-01 12:56:53.948 [INFO ] [rthome.model.script.front_door.rules] - Last open is: 1543665310742
2018-12-01 12:56:53.955 [INFO ] [rthome.model.script.front_door.rules] - Time now is: 1543665413940
2018-12-01 12:56:53.961 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Keep Light On': An error occurred during the script execution: Could not invoke method: org.eclipse.xtext.xbase.lib.IntegerExtensions.operator_minus(int,int) on instance: null
Code is:
rule "Keep Light On"
Item FrontDoor_LightActive changed to ON
var LastOpen = 0
var i = 15
var now = 0
logInfo(log_title, "now is: " + now)
logInfo(log_title, "Triggered wakeup")
while (i > 1) {
now = new DateTimeType().zonedDateTime.toInstant.toEpochMilli
LastOpen = (FrontDoor_LastOpenTime.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli
logInfo(log_title, "Last open is: " + LastOpen)
logInfo(log_title, "Time now is: " + now)
logInfo(log_title, "Calc: " + (now-LastOpen))
if((now-LastOpen+5000) < 0) {
// i = 1
logInfo(log_title, "Time Reached - While loop updates i to 1")
logInfo(log_title, "While loop waits for sleep")
Thread::sleep(2000)
i = i - 1
logInfo(log_title, "i Becomes " + i)
logInfo(log_title, "exit while")
FrontDoor_LightActive.postUpdate(OFF)
After the main door closes, the Hall Light should stay on for 5 minutes. If door opens’closes this timer should change.
I could do it with a trigger of the rule like the sunset/sunrise shows here. but this is my only rule which require something like this.
If we forget about the while loop
why
throws that:
FrontDoor_LightActive_Timer.sendCommand(ON) // Start/Restart Timer
rule "Turn Light OFF"
Item FrontDoor_LightActive_Timer received command OFF
FrontDoor_LightActive.sendCommand(OFF)
This doesn’t solve the case when the door is open for 5 minutes and i want it to start only when door is shut. And if it opens I need to reset this timer.
I have assumed that FrontDoor is your door sensor and FrontDoor_Light is the light item.
Item FrontDoor changed //Door is opened or closed
FrontDoor_Light.sendCommand(ON)
if (FrontDoor.state == OPEN) return; // Door stayed opened for 5 minutes do nothing
FrontDoor_Light.sendCommand(OFF)
val log_title = "front_door.rules"
Item MainDoorSensor_DoorWindowSensor changed
logInfo(log_title, "Door Sensor Change Triggered")
if(MainDoorMultisensor_SensorLuminance.state < 8) {
logInfo(log_title, "Door Sensor - Luminance is low enough")
if (MainDoorSensor_DoorWindowSensor.state == OPEN) {
logInfo(log_title, "Door Still Open")
} else {
logInfo(log_title, "Door is closed, timer also expired")
