Dear ALL,
Could you pls assit me to connect my OpenHab to KNX bus via serial (/dev/ttyACM0).
In brief - I have a TPUART connected to USB and it gives me a /dev/ttyACM0 serial device.
But OpenHab canot connect to the device: "Could not initialize class gnu.io.RXTXCommDriver " and “Serial port ‘/dev/ttyACM0’ could not be opened”
I’ve spend some days trying to solve issue but failed. May be I’m doing something wrong.
Here are some logs & printouts from my server:
Thanks in advance,
Alex
openhab.cgf:
knx:serialPort=/dev/ttyACM0
knx:busaddr=1.1.252
knx:type=TUNNEL
knx:localIp=192.168.1.5
knx:autoReconnectPeriod=60
openhab.sh:
-Dfelix.fileinstall.active.level=4
-Dgnu.io.rxtx.SerialPorts=/dev/ttyACM0
-Djava.awt.headless=true
/var/log/syslog:
Jan 7 19:14:08 nuc openhab.sh[25573]: java.lang.NoClassDefFoundError: Could not initialize class gnu.io.RXTXCommDriver thrown while loading gnu.io.RXTXCommDriver
Jan 7 19:14:08 nuc openhab.sh[25573]: 19:14:08.793 [ERROR] [b.k.i.connection.KNXConnection:225 ] - Error connecting to KNX bus: Serial port ‘/dev/ttyACM0’ could not be opened. Available ports are:
Jan 7 19:14:08 nuc openhab.sh[25573]: 19:14:08.793 [INFO ] [b.k.i.connection.KNXConnection:488 ] - KNX link will be retried in 60 seconds
Jan 7 19:14:08 nuc openhab.sh[25573]: 19:14:08.794 [INFO ] [tuwien.auto.calimero :51 ] - [Timer-5] FT1.2 /dev/ttyACM0: open rxtx library serial port connection
Jan 7 19:14:08 nuc openhab.sh[25573]: 19:14:08.798 [WARN ] [tuwien.auto.calimero :49 ] - [Timer-5] FT1.2 /dev/ttyACM0: rxtx serial port access failed
lsusb:
Bus 002 Device 005: ID 03eb:204b Atmel Corp. LUFA USB to Serial Adapter Project
ls -l /dev/ttyA*:
crw-rw---- 1 root dialout 166, 0 Jan 7 19:13 /dev/ttyACM0
dmesg:
[ 2655.937873] usb 2-1.1: new full-speed USB device number 5 using ehci-pci
[ 2656.032463] usb 2-1.1: New USB device found, idVendor=03eb, idProduct=204b
[ 2656.032474] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=220
[ 2656.032479] usb 2-1.1: Product: TPUART
[ 2656.032484] usb 2-1.1: Manufacturer: busware.de
[ 2656.032488] usb 2-1.1: SerialNumber: 854393439393517141E1
[ 2656.048210] cdc_acm 2-1.1:1.0: ttyACM0: USB ACM device
[ 2656.048573] usbcore: registered new interface driver cdc_acm
[ 2656.048579] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
groups openhab:
openhab: openhab dialout
