I installed openhab 3 on linux machine (zorin 16) and installed visual code, with openhab add on.
However when i try to add folder to workspace and i navigate to /etc openhab does not show. I can navigate to /etc/openhab using file manager.
I guess it has to do with rights. the folder is shared, tried to chmod 777 openhab, but somehow it stays hiddden.
Any body has a suggestion where to look or what config i have to change?
additional info : error in visual code
Usage of deprecated config => openhab.host <= detected.
Usage of deprecated config => openhab.port <= detected.
openHAB vscode extension has been activated
[Error - 4:36:55 PM] Connection to server is erroring. Shutting down server.
Could not reload items for HoverProvider
Could not reload items for Items Explorer
Could not reload items for Things Explorer
Error:
Error while connecting to openHAB REST API.
Message:
Error: getaddrinfo EAI_AGAIN openhabianpi
Error:
Message:
Error:
Message:
Error:
Message:
Vi
Have you configured vs code plugin according to documentation?
Thank you for the tip. Don’t know if I did this correctly, guess not, but will look into that tonight.
The error I made was using VC on the same machine that is running openhab. For reasons I do not understand yet, this does not work.
However when I installed VC on other machine and cofigured plugin correctly, it works.
Thks 4 help
