- Platform information:
- Hardware: Rasperry Pi 3
- OS: openHABianPi 4.9.35-v7+
- Java Runtime Environment: openjdk version “1.8.0_121”
- openHAB version: 2.1
- Issue of the topic:
Hello!
I come from openHAB 1. Everything worked fine. Wanted to go to 2.1 to be ready for the future. I would like to define my items in a file instead of Paper UI, being much more familar with it and want to migrate my old configs, but I cannot get the rollershutter to work.
Thing (Using Paper UI):
Trying to link to the channel homematic:HM-LC-Bl1PBU-FM:ccu:XEQ1234567:1#LEVEL using the following item in file /etc/openhab2/items/arbeitszimmer.items (copying the channel-string with the button in Paper UI (red marker (1) in screenshot above):
Rollershutter AZRollo "Rollo [%s %%]" <rollershutter> { channel="homematic:HM-LC-Bl1PBU-FM:ccu:XEQ1234567:1#LEVEL" }
with the following entry in sitemap-file (/etc/openhab2/sitemaps/test.sitemap):
Switch item=AZRollo
I was expecting, to see an item in Basic or Classic UI let me control the rollershutter, but I only saw a button like the one on the right in the above screenshot marked with (2).
So what am I doing wrong?
Thanks in advance.
Malte
P.S.: Here is the whole items-file:
//Heizung
Number AZ_HEIZUNG_Signal "AZ Heizung Signal [%d %%]" <qualityofservice> (g_qos, g_az) { channel="homematic:HM-CC-RT-DN:ccu:YEQ1212121:0#SIGNAL_STRENGTH" }
Switch AZ_HEIZUNG_LowBat "Heizung Batterien schwach" <lowbattery> (g_lowbat, g_az) { channel="homematic:HM-CC-RT-DN:ccu:YEQ1212121:0#LOWBAT" }
Number AZ_HEIZUNG_Soll "Heizung Solltemp. [%.1f °C]" <temperature> (g_heating, g_az) { channel="homematic:HM-CC-RT-DN:ccu:YEQ1212121:4#SET_TEMPERATURE" }
Number AZ_HEIZUNG_Ist "Heizung Isttemp. [%.1f °C]" <temperature> (g_heating, g_az) { channel="homematic:HM-CC-RT-DN:ccu:YEQ1212121:4#ACTUAL_TEMPERATURE" }
Number AZ_HEIZUNG_Ventil "Heizung Ventil [%d %%]" <temperature> (g_heating, g_az) { channel="homematic:HM-CC-RT-DN:ccu:YEQ1212121:4#VALVE_STATE" }
/Rollo
Number AZRollo_Signal "Rollo AZ Signal [%d %%]" <qualityofservice> (g_qos) { channel="homematic:HM-LC-Bl1PBU-FM:ccu:XEQ1234567:0#SIGNAL_STRENGTH" }
And here is the whole sitemap-file:
sitemap test label="Test" {
Frame label="Wannenbad" {
Slider item=WBPrimLicht
Frame label="Arbeitszimmer" {
Text item=AZRollo_Signal
Switch item=AZRollo
Text item=AZ_HEIZUNG_Signal
Setpoint item=AZ_HEIZUNG_Soll minValue=17 maxValue=28 step=0.5
Text item=AZ_HEIZUNG_Ist
Switch item=AZ_HEIZUNG_LowBat
Text item=AZ_HEIZUNG_Ventil
Text item=Current_DateTime label="Wetter & Astro [%1$tA, %1$td.%1$tm.%1$tY]" icon="sun_clouds" {
Frame label="Aktuell" {
//Switch item=Night_State label="Phase of Day" mappings=[OFF="Tag", ON="Nacht"]
Text item=Day_Phase icon="sunmoon"
Text item=Sonnenaufgang_Time icon="sunrise" visibility=[Night_State == ON]
Text item=Sonnenuntergang_Time icon="sunset" visibility=[Night_State == OFF]
Text item=Sun_Elevation icon="sunmoon" visibility=[Sun_Elevation > 0]
Text item=Moon_Elevation icon="sunmoon" visibility=[Moon_Elevation > 0]
Text item=Sternzeichen icon="zodiac"
Text item=Mondphase
Text item=Moon_Next_Full icon="fullmoon"
visibility=[Moon_Phase == WAXING_CRESCENT,
Moon_Phase == FIRST_QUARTER,
Moon_Phase == WAXING_GIBBOUS,
Moon_Phase == FULL]
Text item=Moon_Next_New icon="fullmoon"
visibility=[Moon_Phase == WANING_GIBBOUS,
Moon_Phase == THIRD_QUARTER,
Moon_Phase == WANING_CRESCENT,
Moon_Phase == NEW]
Frame label="Forecast" {
Text label="This is part of other tutorials..." icon="sun_clouds"
