Hi, I have started playing with openHab but I can’t seem to get the sitemap to return any variable.
I have a clean installation of openHab2.
I have a _default.sitemap file with only the following:
sitemap _default label="My home automation" {
Frame label="Date" {
Text item=Date
I’m expecting to see the date returned but all I see is the word ‘Date’ as in the below clip.
I also see errors in the log:
Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
Cannot retrieve item ‘Date’ for widget org.eclipse.smarthome.model.sitemap.Text
I have installed the 1.x compatibility layer an this is a new install as I thought the original may be corrupt.
I would appreciate any help!
Justin
