Cannot get virtual items to work
I have gotten tips about using virtual items in several threads, but cant seem to get it to work.
Items file:
Number OvenOntoday
Snippet from rule:
var int minutes = (Insight_onToday.state as DecimalType).intValue
minutes = minutes/60
logInfo(“homeautomation”, “oven has been on for " + minutes + " today”)
postUpdate(OvenOntoday,minutes)
Sitemap:
Text item=OvenOntoday
What i would hope was that in the app, i could see the value of minutes in the SiteOnToday item. But, not luck.
Tips?
Try using:
OvenOntoday.postUpdate(minutes)
The postUpdate action doesn’t always handle converting Numbers and primitive values (e.g. int) to a state the Item can understand.
On your sitemap what do you see for OvenOntoday?
Ah, did actually forgot to mention that i had also tried OvenOntoday.postUpdate(minutes).
But thanks! :slightly_smiling:
In my website i just see the name of the item.
It seems your sitemap lacks the necessary information to give you what you want.
Try the following:
Text item=OvenOntoday label="Oven on today [%d minutes]"
That was it! Thank you so much!
