I didnt but i opted for the easy way, re format the SD card and try again. I selected the “expert” install and maybe should have selected the standard one
no. At first I selected EXPERT, and there were no tabs, so I have installed again using STANDARD, and now PAPERUI & BASICUI are available. I guess what I did was drastic, but didnt know any other way to get PAPERUI
You can make this switch without reinstalling. There is a file named addons.cfg in the services folder. “etc/openhab2/services/addons.cfg” on apt installs.
You can change from one package mode to another by editing the file and changing the “package” line.
package = standard
You can also change the legacy line to true to allow for the 1.x bindings. I think you can make that change from paperui as well.
If you want to go with an expert install, once installed, you would need to edit that addons.cfg file to change a few settings. You can read down it as it is well documented within. But suffice it to say you would want to change, “ui” at the very least to get paperui and basicui to config further OR you can do all bindings and config in that file and only install basicui and skip paperui for example.
