Can someone help me please?
This is my rule, sometimes its working but other times i get this error and the rule not working : cannot invoke method public abstract boolean org.eclipse.smarthome.model.script.actions.Timer.hasTerminated() on null
rule "SleepingRoom Windows Open, Close Thermostat"
Item SleepingRoom_Window changed
if(SleepingRoom_Window.state==OPEN) {
if(windopen3===null) {
windopen3 = createTimer(now.plusSeconds(10), [ |
sendCommand(maxSetTempSleepingroom, 4.5)
rule "SleepingRoom restore thermostat"
if (SleepingRoom_Window.state==CLOSED) {
if (windopen3.hasTerminated) { //window open for longer than five minutes so thermostat is OFF
windopen3=null
sendCommand(maxSetTempSleepingroom, maxSetTempSleepingroom.previousState(true).state.toString )
logInfo("windows.rules", "previousState(): " + maxSetTempSleepingroom.previousState(true).state.toString + " state: " + maxSetTempSleepingroom.state.toString)
if (windopen3 !==null ){ //window open less than five minutes, just cancel and clean up the timer
windopen3.cancel
windopen3=null
You’ve shown us two rules, but not said which one produces the error message. Help us to help you, we’re quite happy with a copy-paste from your log.
You can get into that code path when your timer handle windopen3 is null.
Like the message says, you can’t check null to see if it has terminated.
You can check for null, as you do elsewhere. I’m not sure what you want to happen in that case though … go on to do those commands or not.
Sorry you have right, i was not so clear.
the error on logfiles its coming from the second rule. when the window is opened for some hours and when i close the window the rule its not working and get this error :2020-03-27 12:06:17.890 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘SleepingRoom restore thermostat’: cannot invoke method public abstract boolean org.eclipse.smarthome.model.script.actions.Timer.hasTerminated() on null
The code is copy paste from other post and a little bit from me, i am not good in programming but i am learning
What happens if you add var Timer window3 = null to the top of your rules?
Here is an example rule of checking the condition of a timer and reset.
var Timer myTimer = null
rule "Motion OFF"
Item Motion changed from OFF
if (myTimer === null) {
if (Motion.state == ON) {
myTimer = createTimer(now.plusSeconds(60), [ |
if (Motion.state == ON){
//do stuff
rule "BACK FROM ON"
Item Motion changed from ON
myTimer.cancel
myTimer = null
