Hey guys, trying to setup the my.openhab integration. When I start openhab I get the following error:
2016-04-11 11:42:09.227 [WARN ] [o.config.core.ConfigDispatcher] - Cannot parse line 'security:netmask' of main configuration file 'configurations/openhab_default.cfg'.
2016-04-11 11:42:09.920 [WARN ] [o.config.core.ConfigDispatcher] - Main openHAB configuration file '/etc/openhab/configurations/openhab.cfg' does not exist.
2016-04-11 11:42:09.985 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.8.2).
It says it cannot parse the line 'secruity:netmask" but it looks valid to me:
# configures the security options. The following values are valid:
# ON = security is switched on generally
# OFF = security is switched off generally
# EXTERNAL = security is switched on for external requests
# (e.g. originating from the Internet) only
# (optional, defaults to 'OFF')
security:option=EXTERNAL
# the Netmask to define a range of internal IP-Addresses which doesn't require
# authorization (optional, defaults to '192.168.1.0/24')
security:netmask=10.0.0.0/24
# The name of the default persistence service to use
persistence:default=myopenhab
# The refresh interval for the main configuration file. A value of '-1'
# deactivates the scan (optional, defaults to '-1' hence scanning is deactivated)
#mainconfig:refresh=
security:netmask
# Bind service discovery to specific hostname or IP address
#servicediscovery:bind_address=127.0.0.1
