- Platform information:
- Hardware: x86
- OS: Windows 10
- Java Runtime Environment: zulu-8
- Issue of the topic: Cannot run the UI
Hi, I have just installed OH3 but I am getting 404 error when trying to view the UI.
This localhost page can’t be found
No webpage was found for the web address: http://localhost:8080/
In my logs I can see this:
2021-07-25 16:13:34.719 [ERROR] [Events.Framework ] - FrameworkEvent ERROR
org.osgi.framework.BundleException: Could not resolve module: org.openhab.ui.iconset.classic [238]
Unresolved requirement: Require-Capability: osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=11))"
Unresolved requirement: Import-Package: org.openhab.core.i18n
→ Export-Package: org.openhab.core.i18n; bundle-symbolic-name=“org.openhab.core”; bundle-version=“3.1.0”; version=“3.1.0”; uses:=“javax.measure,javax.measure.spi,org.openhab.core.library.types,org.osgi.framework”
org.openhab.core [154]
Unresolved requirement: Import-Package: si.uom
→ Export-Package: si.uom; bundle-symbolic-name=“si-units”; bundle-version=“2.0.1”; version=“2.0.1”; uses:=“javax.annotation,javax.inject,javax.measure,javax.measure.quantity,javax.measure.spi,si.uom.quantity,tech.units.indriya,tech.units.indriya.spi,tech.units.indriya.unit”
si-units [229]
Unresolved requirement: Import-Package: si.uom.quantity
→ Export-Package: si.uom.quantity; bundle-symbolic-name=“si.uom.si-quantity”; bundle-version=“2.0.1”; version=“2.0.1”; uses:=“javax.measure”
si.uom.si-quantity [230]
Unresolved requirement: Require-Capability: osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=9.0))"
Unresolved requirement: Import-Package: com.google.gson; version="[2.8.0,3.0.0)"
→ Export-Package: com.google.gson; bundle-symbolic-name=“com.google.gson”; bundle-version=“2.8.6”; version=“2.8.6”; uses:=“com.google.gson.reflect,com.google.gson.stream”
com.google.gson [37]
Unresolved requirement: Import-Package: org.openhab.core.ui.icon
→ Export-Package: org.openhab.core.ui.icon; bundle-symbolic-name=“org.openhab.core.ui.icon”; bundle-version=“3.1.0”; version=“3.1.0”; uses:=“org.openhab.core.i18n”
org.openhab.core.ui.icon [217]
Unresolved requirement: Import-Package: org.openhab.core; version="[3.1.0,4.0.0)"
→ Export-Package: org.openhab.core; bundle-symbolic-name=“org.openhab.core”; bundle-version=“3.1.0”; version=“3.1.0”
at org.eclipse.osgi.container.Module.start(Module.java:463) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1845) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1838) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1781) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1743) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1665) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.16.200.jar:?]
Could someone tell me what I have done wrong?
