@chris, in case this can provide any help, or out of curiosity:
Bellow, the XML generated data from the Z-Wave Certification product page: https://products.z-wavealliance.org/products/3693. Sent to me 40min. ago by Aeotec
<?xml version="1.0" encoding="utf-8"?>
<ProductExport xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<Id>3693</Id>
<Name>Nano Shutter</Name>
<Description>Aeotec New Generation Nano Shutter
1. Used to control the motor of Curtain, support Shutter Mode and Venetian Mode .
2. Can be calibrated according to diff e rent curtains
3. Used to control other Z-Wave device directly.
4. Support S2, more safe and more re liable
5. Support SmartStart, faster inclusion</Description>
<Description_Short>Aeotec New Generation motor controller</Description_Short>
<Brand>Aeotec</Brand>
<Identifier>ZW141-C</Identifier>
<ProductLine>Z-Wave Plus Device</ProductLine>
<CertificationNumber>ZC10-19116785</CertificationNumber>
<OemVersion>HW: 141 FW: 3.00:01.03</OemVersion>
<HardwarePlatform>ZM5101</HardwarePlatform>
<ZWaveVersion>6.81.03</ZWaveVersion>
<LibraryType>Enhanced 232 Slave</LibraryType>
<DeviceType>Window Covering - Pos/End Aware</DeviceType>
<RoleType>Always On Slave</RoleType>
<ManufacturerId>0x0371</ManufacturerId>
<ProductTypeId>0x0003</ProductTypeId>
<ProductId>0x008D</ProductId>
<FrequencyName>CEPT (Europe)</FrequencyName>
<UserIcon>0x1A00</UserIcon>
<InstallerIcon>0x1A00</InstallerIcon>
<CertificationApprovedDate>2019-10-31T17:38:06.549006</CertificationApprovedDate>
<Categories>
<string>Security Add-Ons</string>
<string>Motor Control</string>
<string>Network Devices</string>
</Categories>
<SupportedCommandClasses>
<CommandClassExport>
<Name>Command Class Association Group Info</Name>
<Identifier>COMMAND_CLASS_ASSOCIATION_GRP_INFO</Identifier>
</CommandClassExport>
<Name>Command Class Association V2</Name>
<Identifier>COMMAND_CLASS_ASSOCIATION_V2</Identifier>
<Name>Command Class Basic V2</Name>
<Identifier>COMMAND_CLASS_BASIC_V2</Identifier>
<Name>Command Class Central Scene V3</Name>
<Identifier>COMMAND_CLASS_CENTRAL_SCENE_V3</Identifier>
<Name>Command Class Configuration</Name>
<Identifier>COMMAND_CLASS_CONFIGURATION</Identifier>
<Name>Command Class Device Reset Locally</Name>
<Identifier>COMMAND_CLASS_DEVICE_RESET_LOCALLY</Identifier>
<Name>Command Class Firmware Update Md V4</Name>
<Identifier>COMMAND_CLASS_FIRMWARE_UPDATE_MD_V4</Identifier>
<Name>Command Class Manufacturer Specific V2</Name>
<Identifier>COMMAND_CLASS_MANUFACTURER_SPECIFIC_V2</Identifier>
<Name>Command Class Powerlevel</Name>
<Identifier>COMMAND_CLASS_POWERLEVEL</Identifier>
<Name>Command Class Scene Activation</Name>
<Identifier>COMMAND_CLASS_SCENE_ACTIVATION</Identifier>
<Name>Command Class Scene Actuator Conf</Name>
<Identifier>COMMAND_CLASS_SCENE_ACTUATOR_CONF</Identifier>
<Name>Command Class Security</Name>
<Identifier>COMMAND_CLASS_SECURITY</Identifier>
<Name>Command Class Security 2</Name>
<Identifier>COMMAND_CLASS_SECURITY_2</Identifier>
<Name>Command Class Supervision</Name>
<Identifier>COMMAND_CLASS_SUPERVISION</Identifier>
<Name>Command Class Switch Multilevel V4</Name>
<Identifier>COMMAND_CLASS_SWITCH_MULTILEVEL_V4</Identifier>
<Name>Command Class Transport Service V2</Name>
<Identifier>COMMAND_CLASS_TRANSPORT_SERVICE_V2</Identifier>
<Name>Command Class Version V2</Name>
<Identifier>COMMAND_CLASS_VERSION_V2</Identifier>
<Name>Command Class Z-Wave+ Info V2</Name>
<Identifier>COMMAND_CLASS_ZWAVEPLUS_INFO_V2</Identifier>
</SupportedCommandClasses>
<ControlledCommandClasses />
<S2Classes>
<S2ClassExport>
<Name>S2 Authenticated</Name>
<Identifier>S2_AUTHENTICATED</Identifier>
</S2ClassExport>
<S2ClassExport>
<Name>S2 Unauthenticated</Name>
<Identifier>S2_UNAUTHENTICATED</Identifier>
</S2ClassExport>
</S2Classes>
<AssociationGroups>
<AssociationGroupExport>
<Description>Used for some commands auto sending when status changed.</Description>
<GroupNumber>1</GroupNumber>
<MaximumNodes>5</MaximumNodes>
<endpoint_id>0</endpoint_id>
<group_name>Lifeline</group_name>
<profile>0x0001</profile>
</AssociationGroupExport>
<Description>Retransmit when receiving the follow commands</Description>
<GroupNumber>2</GroupNumber>
<group_name>Retransmit</group_name>
<profile>0x0000</profile>
</AssociationGroups>
<ConfigurationParameters>
<ConfigurationParameterExport>
<Name>Switch Type of External Switch 1</Name>
<Description>Used to set Switch type of External Switch 1,and reports will return automatically during identify.</Description>
<ParameterNumber>120</ParameterNumber>
<Size>1</Size>
<DefaultValue>0</DefaultValue>
<pType>1</pType>
<flagReadOnly>false</flagReadOnly>
<flagReInclude>false</flagReInclude>
<flagAdvanced>false</flagAdvanced>
<v3plus>false</v3plus>
<minValue>0</minValue>
<maxValue>4</maxValue>
<ConfigurationParameterValues>
<ConfigurationParameterValueExport>
<From>0</From>
<To>0</To>
<Description>Unidentified mode when no identify is set, and indicate identify fails when in identify.</Description>
</ConfigurationParameterValueExport>
<From>1</From>
<To>1</To>
<Description>2-state switch mode</Description>
<From>2</From>
<To>2</To>
<Description>3 way switch mode</Description>
<From>3</From>
<To>3</To>
<Description>Push Button mode</Description>
<From>4</From>
<To>4</To>
<Description>Enter automatic identification mode(The blue led will fast blink)</Description>
</ConfigurationParameterValues>
</ConfigurationParameterExport>
<ParameterNumber>121</ParameterNumber>
<Size>1</Size>
<pType>1</pType>
<From>0</From>
<To>0</To>
<From>1</From>
<To>1</To>
<From>2</From>
<To>2</To>
<From>3</From>
<To>3</To>
<From>4</From>
<To>4</To>
<Name>Motor Behavior After Power ON</Name>
<Description>Setting the Motor Behavior After Power ON.</Description>
<ParameterNumber>20</ParameterNumber>
<Size>1</Size>
<pType>1</pType>
<maxValue>2</maxValue>
<From>0</From>
<To>0</To>
<Description>Stay the same position before power off last time</Description>
<From>1</From>
<To>1</To>
<Description>Moves to 99%</Description>
<From>2</From>
<To>2</To>
<Description>Moves to 0%</Description>
<Name>Determine motor run direction</Name>
<Description>Change the mapping of output and motor running direction
between the 2 directions below:
1. Out1 maps forward and Out2 maps reverse
2. Out1 maps reverse and Out2 maps forward
Note:
1.Motor will stop when receiving this command in moving;
2.This configuration will not change after network exclusion or Configuration
Reset.</Description>
<ParameterNumber>22</ParameterNumber>
<Size>1</Size>
<DefaultValue>2</DefaultValue>
<pType>1</pType>
<minValue>2</minValue>
<From>2</From>
<To>2</To>
<Description>Set to change the motor direction</Description>
<Name>Function Setting of External Switch S1&S2</Name>
<Description>Used to Enable/Disable function of External Switch S1&S2.
Note :
This value can be combine, e.g. set to 3(1+2=3),means networking function and Reset function are both enable.</Description>
<ParameterNumber>248</ParameterNumber>
<Size>1</Size>
<DefaultValue>1</DefaultValue>
<pType>1</pType>
<minValue>1</minValue>
<From>1</From>
<To>1</To>
<Description>Enable network function, inclusion/exclusion</Description>
<From>2</From>
<To>2</To>
<Description>Enable reset to factory default function</Description>
<Name>Reset Function</Name>
<Description>Used to reset configuration parameter value to default value or reset to factory default settings.
Note:
Parameter 0x16, 0x22, 0x23, 0x24, 0x25, 0x27, 0x28 will not reset to default value by this command.</Description>
<ParameterNumber>255</ParameterNumber>
<Size>4</Size>
<pType>1</pType>
<maxValue>1431655765</maxValue>
<From>0</From>
<To>0</To>
<Description>Reset all configuration parameters to default settings</Description>
<From>1431655765</From>
<To>1431655765</To>
<Description>reset to factory default settings and removed from the z-wave network</Description>
<Name>Set the Blade Turn Time</Name>
<Description>This parameter is to config the blade turn time(unit = 0.01s),which works only for venetian mode.Details can be found in section 4.2 of Advanced information Product Manual.
Note:
For Venetian, if this value is set too large for blade turning, curtain may move upwards or downwards.
Calibration need to work correctly.Or this setting will force the curtain to move up or down.
This configuration will not change after network exclusion or Configuration Reset.</Description>
<ParameterNumber>34</ParameterNumber>
<Size>2</Size>
<DefaultValue>150</DefaultValue>
<pType>1</pType>
<minValue>10</minValue>
<maxValue>32767</maxValue>
<From>10</From>
<To>32767</To>
<Description>0.1 - 327.67seconds</Description>
<Name>Curtain Trip Time</Name>
<Description>Curtain Trip Time is about the run time of the curtain (unit = 0.01s). Details can be found in section 4.2 of Advanced information Product Manual.
Note:
<ParameterNumber>35</ParameterNumber>
<Size>2</Size>
<DefaultValue>15000</DefaultValue>
<pType>1</pType>
<minValue>500</minValue>
<From>500</From>
<To>32767</To>
<Description>5 - 327.67 seconds</Description>
<Name>Enter/Exit Calibration</Name>
<Description>Note:
Product will enter the right Curtain Mode after calibration, see Configuration 0x27(39)</Description>
<ParameterNumber>36</ParameterNumber>
<Size>1</Size>
<pType>1</pType>
<From>0</From>
<To>0</To>
<Description>Set:Exit Calibration Report: Not in Calibration</Description>
<From>1</From>
<To>1</To>
<Description>Set:Enter Shutter Mode Calibration Report: In Shutter Mode Calibration</Description>
<From>2</From>
<To>2</To>
<Description>Set:Enter Venetian Mode Calibration Report: In Venetian Mode Calibration</Description>
<Name>User confirmation for Calibration</Name>
<Description>User confirmation for Calibration(set only)</Description>
<ParameterNumber>37</ParameterNumber>
<Size>1</Size>
<pType>1</pType>
<maxValue>0</maxValue>
<From>0</From>
<To>0</To>
<Description>Go to next step of calibration</Description>
<Name>Calibration Status Report </Name>
<Description>Return Calibration Status(Get or Report)</Description>
<ParameterNumber>38</ParameterNumber>
<Size>1</Size>
<pType>1</pType>
<maxValue>5</maxValue>
<From>0</From>
<To>0</To>
<Description>Calibration Complete</Description>
<From>1</From>
<To>1</To>
<Description>Calibration start, going to Reference Point A</Description>
<From>2</From>
<To>2</To>
<Description>Reach Reference Point A, going to Reference Point B</Description>
<From>3</From>
<To>3</To>
<Description>Reach Reference Point B, waiting for Blade turn Calibraion(Only for Venetian Mode)</Description>
<From>4</From>
<To>4</To>
<Description>Going to Reference Point C(Only for Venetian Mode)</Description>
<From>5</From>
<To>5</To>
<Description>Calibration terminated</Description>
<Name>Cutain Mode Setting</Name>
<Description>Set the Curtain Mode.
Note:
1. This Operation will enter repositioning automatically;
2. This configuration will not change after network exclusion or Configuration Reset.</Description>
<ParameterNumber>39</ParameterNumber>
<Size>1</Size>
<pType>1</pType>
<maxValue>1</maxValue>
<From>0</From>
<To>0</To>
<Description>Shutter Mode</Description>
<From>1</From>
<To>1</To>
<Description>Venetian Mode</Description>
<Name>Repositioning</Name>
<Description>Set to begin repositioning.</Description>
<ParameterNumber>40</ParameterNumber>
<Size>1</Size>
<pType>1</pType>
<From>1</From>
<To>1</To>
<Description>Repositioning begins</Description>
<Name>Repositioning Status Report</Name>
<Description>Used to Get repositioning Status.</Description>
<ParameterNumber>41</ParameterNumber>
<Size>1</Size>
<pType>1</pType>
<From>0</From>
<To>0</To>
<Description>Repositioning complete</Description>
<From>1</From>
<To>1</To>
<Description>in repositioning</Description>
<Name>Calibration Lock</Name>
<Description>Used to enable/disable calibration lock from different ways.</Description>
<ParameterNumber>42</ParameterNumber>
<Size>1</Size>
<pType>1</pType>
<From>0</From>
<To>0</To>
<Description>Disable calibration</Description>
<From>1</From>
<To>1</To>
<Description>Enable Action Button/ Command Calibration</Description>
<From>2</From>
<To>2</To>
<Description>Enable Action Button/ Command/S1/S2 Calibration</Description>
<Name>Switch Status Report Selection</Name>
<Description>Choose which report to send when switch status change</Description>
<ParameterNumber>80</ParameterNumber>
<Size>1</Size>
<pType>1</pType>
<From>0</From>
<To>0</To>
<Description>No Report</Description>
<From>1</From>
<To>1</To>
<Description>Basic Report</Description>
<From>2</From>
<To>2</To>
<Description>Switch Multilevel Report</Description>
<Name>Extern Button Mode Setting</Name>
<Description>Extern Button Mode Setting</Description>
<ParameterNumber>85</ParameterNumber>
<Size>1</Size>
<pType>1</pType>
<From>0</From>
<To>0</To>
<Description>Extern Button 1 maps to Z-wave Button,Extern Button 2 opens or stops motor.</Description>
<From>1</From>
<To>1</To>
<Description>Extern Button 1 maps to Z-wave Button,Extern Button 2 closes or stops motor.</Description>
</ConfigurationParameters>
<Features>
<FeaturesProductsExport>
<feature_Id>10</feature_Id>
<product_Id>3693</product_Id>
<option_value_bool>false</option_value_bool>
<option_value_text />
<option_value_selections>
<string>White</string>
</option_value_selections>
<feature_Type>eSelect_One</feature_Type>
<featureName>Color</featureName>
<featureDescription>If the product is only available in one color, pick the color from the list.</featureDescription>
<featurePrompt>Choose one color for the product's main color component. Not for use with products available in multiple colors.</featurePrompt>
</FeaturesProductsExport>
<feature_Id>22</feature_Id>
<string>Updatable by Consumer by RF</string>
<featureName>Firmware Updatable</featureName>
<featureDescription>Indicates whether the firmware can be updated and whether it is done by the consumer or a technician.</featureDescription>
<featurePrompt>Choose one.</featurePrompt>
<feature_Id>28</feature_Id>
<option_value_bool>true</option_value_bool>
<feature_Type>eYes_No</feature_Type>
<featureName>Neutral Wire Required</featureName>
<featureDescription>For electric in-wall/wired switches, indicate whether a neutral wire is required for installation.</featureDescription>
<featurePrompt />
<feature_Id>14</feature_Id>
<option_value_text>2.5A</option_value_text>
<feature_Type>eEnter_Text</feature_Type>
<featureName>Switch Load Capacity Current</featureName>
<featureDescription>The amount of switch load energy the product is rated for in Amps</featureDescription>
<featurePrompt>Enter Amps (not VA or mA) only</featurePrompt>
<feature_Id>31</feature_Id>
<string>Manual Calibration</string>
<string>Supports Horizontal Blinds/Louvers</string>
<string>Supports Up/Down Motion</string>
<feature_Type>eSelect_Many</feature_Type>
<featureName>Window Covering Control Features</featureName>
<featureDescription>Select the feature(s) supported in the Window Covering Control product.</featureDescription>
<featurePrompt>Use the CTRL key to select more than one.</featurePrompt>
</Features>
<Documents>
<ProductsDocuments>
<Id>26643</Id>
<product_id>3693</product_id>
<Type>21</Type>
<description>Product Image</description>
<value>product_pictures/ZC10-19116785.png</value>
<not_public>false</not_public>
</ProductsDocuments>
<ProductsDocuments>
<Id>26547</Id>
<Type>1</Type>
<description>Product Manual</description>
<value>product_documents/3693/Nano Shutter - Product Manual.pdf</value>
<ProductsDocuments>
<Id>26548</Id>
<Type>4</Type>
<description>Product Manual in English</description>
<ProductsDocuments>
<Id>26549</Id>
<Type>2</Type>
<description>Advanced Information Product Manual</description>
<value>product_documents/3693/Nano Shutter - Advanced Information Product Manual.pdf</value>
</Documents>
<Texts>
<ProductsTexts>
<Id>34000</Id>
<Type>2</Type>
<description>Classic Exclusion</description>
<value>3.6 How to Remove the device from Z-Wave network
1. Set your Z-Wave Controller into its 'Remove Device' mode in order to remove the product from your Z-Wave system.Refer to the Controller's manual if you are unsure of how to perform this step.
2. Click Action Button/S1/S2(external switch need to be identified first) 6 times will enter exclusion mode.
3. If Removing fails, it will bright red light for 2s then turn back to Regular Light Mode, repeat steps 1-2. Contact us for further support if needed.
4. If Removing succeeds, it will become breathing blue light. Now, it is removed from Z-Wave network successfully.</value>
</ProductsTexts>
<ProductsTexts>
<Id>34003</Id>
<Type>5</Type>
<description>Factory Reset Procedure</description>
<value>3.7 How to Factory Reset
Manually, press and hold the Action Button for at least 20s and then release. The LED indicator will become breathing blue light, which indicates the reset operation is successful. Otherwise, please try again. Contact us for further support if needed.
Note:
1. This procedure should only be used when the primary controller is missing or inoperable.
2. Factory Reset will:
a) Remove the product from Z-Wave network;
b) Delete the Association setting;</value>
</ProductsTexts>
<ProductsTexts>
<Id>33998</Id>
<Type>8</Type>
<description>Where to find S2 DSK on product</description>
<value>There is no DSK on the product.QR code used for SmartStart inclusion. DSK code can be found on packaging.</value>
</ProductsTexts>
<ProductsTexts>
<Id>34005</Id>
<Type>6</Type>
<description>Other Special Features</description>
<value>Calibration for Shutter have 2 modes: Shutter Mode for Standard roller blind, and Venetian Mode for Venetian Blind. Shutter will record the Curtain Trip Time for Shutter mode and Curtain Trip Time + Blade Turn Time for Venetain Mode.
The detail can be found in section 4.2 Calibration in Advanced information Product Manual.</value>
</ProductsTexts>
<ProductsTexts>
<Id>33999</Id>
<Type>1</Type>
<description>Classic Inclusion</description>
<value>3.5.2 Classic inclusion Learn Mode
1. Set your Z-Wave Controller into its 'Add Device' mode in order to add the product into your Z-Wave system. Refer to the Controller's manual if you are unsure of how to perform this step.
2. Make sure the product is powered. If not, plug it into a wall socket and power on; its LED will be breathing blue light all the time.
3. Click Action Button once, it will quickly flash blue light for 30 seconds until it is added into the network. It will become constantly bright yellow light after being assigned a NodeID.
4. If your Z-Wave Controller supports S2 encryption, enter the first 5 digits of DSK into your Controller's interface if/when requested. The DSK is printed on its housing.
5. If Adding fails, it will bright red light for 2s and then become breathing blue light; repeat steps 1 to 4. Contact us for further support if needed.
6. If Adding succeeds, it will bright blue light for 2s and then turn to Load Indicator Mode. Now, this product is a part of your Z-Wave home control system. You can configure it and its automations via your Z-Wave system; please refer to your software's user guide for precise instructions</value>
</ProductsTexts>
</Texts>
<SupportedMultilevelSensors />
<ControlledMultilevelSensors />
<SupportedNotificationTypes />
<ControlledNotificationTypes />
<SupportedControlledMeterTypes />
<Supports_NWI>true</Supports_NWI>
<Supports_Explorer>true</Supports_Explorer>
<is_FLiRS>false</is_FLiRS>
<Supports_SmartStart>true</Supports_SmartStart>
</ProductExport>
