I am trying to access a Modbus device with RS485 interface, but I cannot make it work. I am using both official Modbus binding, and my own one. I am using OpenHAB 2.5.0-M3 build.
I have seen many similar issues here, like ARM board and MODBUS rs485 converter, but I have not seen any solution (but using a RTU-TCP proxy).
Here is the error:
2019-10-09 19:12:51.605 [ERROR] [impi.modbus.io.ModbusSerialTransport] - Transmit Echo not received
2019-10-09 19:12:51.657 [ERROR] [pi.modbus.io.ModbusSerialTransaction] - execute try 1/1 error: I/O failed to write. Request: net.wimpi.modbus.msg.ReadMultipleRegistersRequest@53d9fc5a (unit id 1 & transaction 1). Serial parameters: SerialParameters@3a7d9ca3[portName=/dev/ttyS1,baudRate=19200,flowControlIn=none,flowControlOut=none,databits=8,stopbits=1,parity=none,encoding=rtu,echo=true,receiveTimeoutMillis=1500]
I am sure that the system is able to reach the device, as this piece of code works fine (uses libmodbus):
ctx = modbus_new_rtu(dev, B19200, 'N', 8, 1);
modbus_set_slave(ctx, slave_id);
modbus_connect(ctx);
sz = modbus_read_registers(ctx, 0x5000, HOLDING_SZ, (uint16_t *) buf);
Any help greatly appreciated!
Hardware: Axon M205 - https://www.unipi.technology/unipi-axon-m205-p180?categoryId=20
System: Debian 9.11
OpenHAB: 2.5.0-M3
Thanks!
Bubuche
