i’ve a big problem with the neo coolcam door/window sensor. when i’ll include this sensor, the device will be shown as unknown z-wave node 43 in the inbox.
i use the follow z-wave snapshot version:
2.2.3 download-date: 08-01-2017
in habmin ui, there is no manufactor and type shown.
I have 9 of those sensors and also the Z-stick. Initally I also had trouble to get them fully included.
I put the stick in inclusion mode, pushed the button 3 times on the sensor. Put the stick back into the PC and ended up with unknown devices.
No matter how often I would wake them up, they would still stay unknown.
Now here was my solution:
BEFORE mounting them to the window, do the inclusion with the stick as you would normally do.
Then put the stick back into the PC.
Take the sensor real close to the stick, which is now connected to the PC.
Push the sensor button 3 times.
You might have to repeat the last step 2 or 3 times.
Now they work like a charm for me. They are really good value for the money.
Same here.
Devices included successfully, report open/close without any problems - but battery status is never updated.
Tried to use different methods to obtain bat level (battery-level and command=battery) but to no avail:
Openhab 2.4 on OrangePi, default zwave binding.
On the same network I have a few Danfoss LC13Z TRVs, those report the battery just fine.
I haven’t changed any associations on the Neo Coolcam sensors but the description says it should send BATTERY_REPORT on the group 1 as well as NOTIFICATION_REPORT and SENSOR_BINARY_REPORT.
Hi all
I have the same issue with battery in a new NAS-DS01Z Door/Window Sensor
I’ve tried several things, but I’m not able to get the battery level
Does anyone a way to fix it?
