I used to be able to connect with my laptop to OpenHab on my raspberry pi using “raspberrypi.local:8080/openhab.app?sitemap=home” but since I’ve open an account with myOpenHab and change the security settings in openhab.cfg I can’t anymore.
I’m able with my phone if I don’t use the wifi but when using wifi it won’t work, on my Mac it ask me for a username and password, I used the myOpenHab password but to no sucess.
The problem I think is here “security:netmask” I’ve entered different settings but it doesn’t work.
I’m pretty sure that won’t work on the long run if you try to connect with other devices.
You need to have .0/24 at the end.
For more explanation see http://software77.net/cidr-101.html
and maybe use the calculator here: http://jodies.de/ipcalc
Type in your Pi’s IP adress and calculate, You will see the string you have to put in your config after Network:
