Hi all
I’m not able to connect to the webgui which is running on a Centos 7 Server. My Client is a OSX 10.10.
The Openhab 1.7 is starting up and is running (checked with netstat -an | grep LIST
[root@scheat configurations]# netstat -an|grep LIST
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:8443 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:8001 0.0.0.0:* LISTEN
tcp6 0 0 :::22 :::* LISTEN
unix 2 [ ACC ] STREAM LISTENING 18987 private/tlsmgr
unix 2 [ ACC ] SEQPACKET LISTENING 13674 /run/udev/control
unix 2 [ ACC ] STREAM LISTENING 19041 private/anvil
unix 2 [ ACC ] STREAM LISTENING 19044 private/scache
unix 2 [ ACC ] STREAM LISTENING 17018 /var/run/NetworkManager/private
unix 2 [ ACC ] STREAM LISTENING 9856 /run/systemd/private
unix 2 [ ACC ] STREAM LISTENING 18990 private/rewrite
unix 2 [ ACC ] STREAM LISTENING 16006 /var/run/dbus/system_bus_socket
unix 2 [ ACC ] STREAM LISTENING 18993 private/bounce
unix 2 [ ACC ] STREAM LISTENING 18996 private/defer
unix 2 [ ACC ] STREAM LISTENING 18999 private/trace
unix 2 [ ACC ] STREAM LISTENING 18976 public/pickup
unix 2 [ ACC ] STREAM LISTENING 18980 public/cleanup
unix 2 [ ACC ] STREAM LISTENING 18983 public/qmgr
unix 2 [ ACC ] STREAM LISTENING 19005 public/flush
unix 2 [ ACC ] STREAM LISTENING 19020 public/showq
unix 2 [ ACC ] STREAM LISTENING 19002 private/verify
unix 2 [ ACC ] STREAM LISTENING 19008 private/proxymap
unix 2 [ ACC ] STREAM LISTENING 19011 private/proxywrite
unix 2 [ ACC ] STREAM LISTENING 19014 private/smtp
unix 2 [ ACC ] STREAM LISTENING 19017 private/relay
unix 2 [ ACC ] STREAM LISTENING 8646 /run/systemd/journal/stdout
unix 2 [ ACC ] STREAM LISTENING 13771 /run/lvm/lvmetad.socket
unix 2 [ ACC ] STREAM LISTENING 19023 private/error
unix 2 [ ACC ] STREAM LISTENING 19026 private/retry
unix 2 [ ACC ] STREAM LISTENING 19029 private/discard
unix 2 [ ACC ] STREAM LISTENING 19032 private/local
unix 2 [ ACC ] STREAM LISTENING 19035 private/virtual
unix 2 [ ACC ] STREAM LISTENING 19038 private/lmtp
also I can connect on the Server local via Telnet:
[root@scheat configurations]# telnet 192.168.1.6 8080
Trying 192.168.1.6…
Connected to 192.168.1.6.
Escape character is ‘^]’.
get
HTTP/1.1 400 Bad Request
Content-Length: 0
Connection: close
Server: Jetty(8.1.3.v20120522)
Connection closed by foreign host.
but not via remote client
grus:Downloads mike$ telnet 192.168.1.6 8080
Trying 192.168.1.6…
telnet: connect to address 192.168.1.6: Connection refused
telnet: Unable to connect to remote host
I have absolute no idea what’s wrong.
thanks for any help
br Michael
PS: selinux is on permissive mode, also no error in the logs of the Server
