- Platform information:
- Hardware: Mac Mini
- OS: Mojave
- Java Runtime Environment: 1.8.0_221-b11
- openHAB version: 2.5.3
I’m using the HUE binding to control lights attached to my HUE bridge.
Besides other lights a Sunricher RGB+CCT controller is attached to the bridge. I can turn on/off the strip and control the color temperature. But I don’t manage to control the RGB colors. The strip controller appears as a single device towards the HUE bridge. On my sitemap I use 3 types to control the strip: a switch (ok), a slider for the color temp. (ok) and a colorpicker. I discovered things via auto-discovery.
Issue: The saturation slider of the color picker controls the brightness instead of saturation. The color picker itself has no effect on the color at all.
- The bridge’s strip (ID9) configuration:
"state": {
"on": true,
"bri": 254,
"hue": 19127,
"sat": 254,
"effect": "none",
"xy": [
0.1439,
0.1724
"ct": 337,
"alert": "select",
"colormode": "ct",
"mode": "homeautomation",
"reachable": true
"swupdate": {
"state": "notupdatable",
"lastinstall": "2020-03-28T16:52:14"
"type": "Extended color light",
"name": "Bibliothek",
"modelid": "RGB-CCT",
"manufacturername": "Sunricher",
"productname": "Extended color light",
"capabilities": {
"certified": false,
"control": {
"colorgamuttype": "other",
"ct": {
"min": 155,
"max": 450
"streaming": {
"renderer": false,
"proxy": false
"config": {
"archetype": "huelightstrip",
"function": "mixed",
"direction": "omnidirectional"
"uniqueid": "ec:1b:bd:ff:fe:98:6f:ab-01",
"swversion": "2.5.3_r47"
- Channel Configuration
A channel of type “hue:0210:ecb5fa217ce1:9:color” has been configured and linked to an item.
Log when trying to change the color to red:
18:29:07.093 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Bibliothek_Farbe' received command 3.2122097601091415,70.11015385426983,100.0
18:29:07.094 [INFO ] [arthome.event.ItemStatePredictedEvent] - Bibliothek_Farbe predicted to become 3.2122097601091415,70.11015385426983,100.0
18:29:07.096 [INFO ] [smarthome.event.ItemStateChangedEvent] - Bibliothek_Farbe changed from 121,100,100 to 3.2122097601091415,70.11015385426983,100.0
18:29:07.395 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Bibliothek_Farbe' received command 3.2122097601091415,70.11015385426983,100.0
18:29:07.396 [INFO ] [arthome.event.ItemStatePredictedEvent] - Bibliothek_Farbe predicted to become 3.2122097601091415,70.11015385426983,100.0
18:29:13.653 [INFO ] [smarthome.event.ItemStateChangedEvent] - Bibliothek_Farbe changed from 3.2122097601091415,70.11015385426983,100.0 to 3,100,100
