Hi there,
I installed openhab and the homegear binding.
I installed three components and two work properly, one device does not work.
I paired them using homegear
**(Family)> peers list
ID │ Name │ Address │ Serial Number │ Type │ Type String │ Firmware │ Config Pending │ Unreach │ Low Bat
1 │ OG_LICHT_BUERO │ 51FF7E │ NEQ1551xxx │ 0069 │ HM-LC-Sw1PBU-FM │ 2.8 │ No │ No │ No
2 │ EG_STROM_TV │ 521D31 │ NEQ1559xxx │ 00D7 │ HM-ES-PMSw1-Pl-DN-R1 │ 2.5 │ No │ No │ No
3 │ EG_LICHT_KUECHE │ 51FF86 │ NEQ1551xxx │ 0069 │ HM-LC-Sw1PBU-FM │ 2.8 │ No │ No │ No
This is the way I included the switches in openhab items file:
Group gruppeAlles
Group test (gruppeAlles)
Switch eg_licht_kueche "Küche" (test) {homematic="address=NEQ155xxxx, channel=1, parameter=STATE"}
Switch og_licht_buero "Büro" (test) {homematic="address=NEQ155xxxx, channel=1, parameter=STATE"}
og_licht_buero works fine
eg_licht_kueche does not work.
Extracts from the logfile:
2016-12-14 10:21:13 - eg_licht_kueche received command ON
2016-12-14 10:21:13.612 [WARN ] [.b.h.i.c.HomematicCommunicator] - Can't find DatapointConfig[address=NEQ155xxxx,channel=1,parameter=STATE], value is not published to Homematic server!
==> /var/log/openhab/2016_12_14.request.log <==
192.168.188.28 - - [14/Dez/2016:09:21:13 +0000] "GET /CMD?eg_licht_kueche=TOGGLE&__async=true&__source=wa0000 HTTP/1.1" 200 13
192.168.188.28 - - [14/Dez/2016:09:21:07 +0000] "GET /openhab.app?sitemap=Haus&sitemap=Haus&w=0000&poll=true&__async=true&__source=wa0000 HTTP/1.1" 200 1716
192.168.188.28 - - [14/Dez/2016:09:21:14 +0000] "GET /images/switch-on.png HTTP/1.1" 304 0
State is not updated correctly. In the WebUI the switch is marked as ON but there is no signal sent via homegear (no log entries). So I do not think that it’s a problem with the component as pairing worked fine and the other components also work fine.
Do you have any hints for my how to get the component work? I Cannot see any differences between the to lines (except the name and the address).
