- Platform information:
- Hardware: CPUArchitecture/RAM/storage
- OS: what OS is used and which version
- Java Runtime Environment: which java platform is used and what version
- openHAB version:
- Issue of the topic: please be detailed explaining your issue
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
I want to learn OpenHab2. I want to follow the tutorial on http://docs.openhab.org/tutorials/beginner/sitemap.html
I Installed openHabian on a RapberryPi3 but I can’t find this location: conf/items/default.items
what can I do?
Should I studdy Linux before doing openhanded?
What is the recommended way to start with openhab?
If you did an installation acording the manual, the folder should be found here::
/opt/openhab2/conf/items
For a repository installation (like openhabian) it would be:
/etc/openhab2/conf/items
For a startup you should study the Beginners Tutorial. In long run you will need some linux knowledge, but you will get it during the usage!
