as a openHAB2 beginner i dig in the documentation
…The files’ location is in the $OPENHAB_CONF…
no i can’t find a directory called OPENHAB_CONF
also there
no hint about this $OPENHAB_CONF
also there
for example /etc/openhab2/sitemaps
if you are on an apt install.
There seems to be some confusion…
$OPENHAB_CONF
is not a directory but an environment variable. If you run OH on Linux (e.g. RaspberryPi) you can check these environment variables with the command:
echo $OPENHAB_CONF
If you run on Windows, use:
echo %OPENHAB_CONF%
The actual directory path is the value of this environment variable. The standard file locations on Linux can be found here in the docs.
