KlingsporC
(Christian Klingspor)
July 31, 2021, 11:08am
1
After a final crash on my RPi w. OH2 I decided to bite the bullet and move on to OH3. To avoid the issues I have had on the Pi, I decided to go for a NUC with Docker which is already in use for Influx an Grafana. The problem is that OH doesn’t “see” the Aeotec zwave-device. I understand from the documentation that you have to allow permissions for the openhab container to access the usb/serial device, so I tried the following:
> docker exec -d openhab /bin/chmod o+rw /dev/ttyACM0
But nothing pops up in the inbox. The command below shows that the device is connected and identified by Ubuntu:
> udevadm info /dev/ttyACM0
E: ID_MODEL_FROM_DATABASE=Aeotec Z-Stick Gen5 (ZW090) - UZB
I also tried setting the device directly in the docker-compose file, but still no luck.
Any ideas on how to move forward?
openhab:
image: "openhab/openhab:3.1.0"
restart: always
network_mode: host
volumes:
- "/etc/localtime:/etc/localtime:ro"
- "/etc/timezone:/etc/timezone:ro"
- "./openhab_addons:/openhab/addons"
- "./openhab_conf:/openhab/conf"
- "./openhab_userdata:/openhab/userdata"
ports:
- 8080:8080
- 8443:8443
environment:
OPENHAB_HTTP_PORT: "8080"
OPENHAB_HTTPS_PORT: "8443"
EXTRA_JAVA_OPTS: "-Duser.timezone=Europe/Berlin"
USER_ID: "997"
GROUP_ID: "997"
devices:
- "/dev/ttyACM0:/dev/ttyACM0:rwm"
Platform information:
Hardware: Intel NUC
OS: Ubuntu 20.4.1 with Docker and Docker compose
openHAB version: 3.1.0
Does User ID 997 have read & write access to the host port?
KlingsporC
July 31, 2021, 12:51pm
3
Yes I think so - user/group 997 is the openhab user:
> id openhab
uid=997(openhab) gid=997(openhab) groups=997(openhab)
Isn’t that what the “docker exec…” command is supposed to do?
Not if the underlying user on the OS does not already have the needed access.
KlingsporC
July 31, 2021, 4:34pm
5
Ok, gave that a try:
> ls -l /dev/ttyACM0
crw-rw---- 1 root dialout 166, 0 Jul 31 10:01 /dev/ttuACM0
> usermod -a -G dialout openhab
> id openhab
uid=997(openhab) gid=997(openhab) groups=997(openhab),20(dialout)
Didn’t work. nothing in the inbox so as a last resort I tested chmod 777 /dev/ttyACM0, but nothing.
Am I missing something fundamental here?
I use Docker run instead of Docker-compose & “cheat” by running in privileged mode which gives access to all ports & devices.
KlingsporC
July 31, 2021, 5:24pm
7
I tried privileged in compose and it didn’t work either. Would you mind sharing your run-command? Maybe there is something wrong with my zwave-stick
Fist step. Are you sure the stick is at /dev/ttyACM0
? What is the output of sudo dmesg | grep tty
? The stick may be somewhere else.
KlingsporC
August 1, 2021, 10:50am
9
Thanks for trying. sudo dmesg | grep tty
returns nothing. udevadm info /dev/ttyACM0
, which I thought verified that I used the correct port returns:
No guarantees, but you can try this. The backslashes are for readability since it is all on one line. the backslashes remove the line breaks for the OS.
docker run --init -d \
--name openhab \
--privileged \
--restart=unless-stopped \
-v /etc/localtime:/etc/localtime:ro \
-v /etc/timezone:/etc/timezone:ro \
-v ./openhab_addons:/openhab/addons \
-v ./openhab_conf:/openhab/conf \
-v ./openhab_userdata:/openhab/userdata \
-e USER_ID=997 \
-e GROUP_ID=997 \
-e OPENHAB_HTTP_PORT=8080 \
-e OPENHAB_HTTPS_PORT=8443 \
-e "EXTRA_JAVA_OPTS=-Duser.timezone=Europe/Berlin" \
--network=host \
KlingsporC
August 1, 2021, 8:55pm
11
Thanks, but still no luck. This might be a bigger issue - I found this thread on the subject: Z-Wave USB stick not working after OH 3.1 update
