Platform information:
- Hardware: x86_64/4GB/120GB
- OS: Ubuntu 18.04.5 LTS / kernel 4.15.0-117-generic
- Java Runtime Environment: openjdk version “1.8.0_262”
- openHAB version: 2.5.7-1
Issue of the topic:
I can’t manage to get the output of the verisure binding to a separate logfile as described by the OH documentation. It works for other bindings. This is the entries in org.ops4j.pax.logging.cfg:# Verisure Logger log4j2.logger.verisure.name = org.openhab.binding.verisure log4j2.logger.verisure.level = DEBUG log4j2.logger.verisure.additivity = false log4j2.logger.verisure.appenderRefs = verisure log4j2.logger.verisure.appenderRef.verisure.ref = VERISURE # Verisure File Appender - verisure.log log4j2.appender.verisure.name = VERISURE log4j2.appender.verisure.type = RollingRandomAccessFile log4j2.appender.verisure.fileName = ${openhab.logdir}/verisure.log log4j2.appender.verisure.filePattern = ${openhab.logdir}/verisure.log.%i log4j2.appender.verisure.immediateFlush = true log4j2.appender.verisure.append = true log4j2.appender.verisure.layout.type = PatternLayout log4j2.appender.verisure.layout.pattern = %d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n log4j2.appender.verisure.policies.type = Policies log4j2.appender.verisure.policies.size.type = SizeBasedTriggeringPolicy log4j2.appender.verisure.policies.size.size = 3MB log4j2.appender.verisure.strategy.type = DefaultRolloverStrategy log4j2.appender.verisure.strategy.max = 10 log4j2.logger.org_openhab_binding_verisure.level = DEBUG log4j2.logger.org_openhab_binding_verisure.name = org.openhab.binding.verisure
The last two entries are what is created by default from openhab when running log:set DEBUG org.openhab.binding.verisure. That works, the debug output is coming to the openhab.log, but not to verisure.log.
This is the output of log:get ALL:
Logger │ Level ___________________________________________________|______ ROOT │ WARN javax.jmdns │ ERROR javax.mail │ ERROR org.apache.karaf.jaas.modules.audit │ INFO org.apache.karaf.kar.internal.KarServiceImpl │ ERROR org.apache.karaf.shell.ssh.SshUtils │ ERROR org.apache.karaf.shell.support │ OFF org.apache.sshd │ ERROR org.eclipse.lsp4j │ OFF org.eclipse.smarthome │ INFO org.eclipse.smarthome.model.script.timerlights │ DEBUG org.jupnp │ ERROR org.openhab │ INFO org.openhab.binding.nibeuplink │ INFO org.openhab.binding.rfxcom │ DEBUG org.openhab.binding.smhi │ DEBUG org.openhab.binding.verisure │ INFO org.openhab.binding.zwave │ DEBUG org.openhab.ui.paper │ WARN org.openhab.ui.paper.internal │ INFO org.ops4j.pax.url.mvn.internal.AetherBasedResolver │ ERROR org.ops4j.pax.web.pax-web-runtime │ OFF smarthome.event │ INFO smarthome.event.InboxUpdatedEvent │ ERROR smarthome.event.ItemAddedEvent │ ERROR smarthome.event.ItemRemovedEvent │ ERROR smarthome.event.ItemStateEvent │ ERROR smarthome.event.ThingAddedEvent │ ERROR smarthome.event.ThingRemovedEvent │ ERROR smarthome.event.ThingStatusInfoEvent │ ERROR
Another observation I made is that when using log:set to change the loglevel to INFO on for example the zwave binding, the output from log:get still shows DEBUG as it should because I have made the same configuration for the zwave binding, with DEBUG loglevel to a separate log file. However when changing the loglevel to INFO on the verisure binding, it also changes in the output from log:get. It is as if openhab ignores my configuration for the verisure binding?
I don’t know if this is a problem with the logging facility, with the binding or with my configuration. Any help nailing down the problem would be much appreciated!
The only difference I see between this and the zwave config I have is that appenderRefs, appenderRef.verisure.ref, and the appender name are all identical. You have appenderRefs all lower case.
I don’t look at logs through the console so I can’t comment on the other behaviors you see.
Do you have any suggestions on how to troubleshoot this? Any form of debug logging that can be activated or other other ways to peek inside and see why the configuration does not work?
Read through the Log4j2 docs and see if some error becomes apparent. All I can offer is it can work so there must be something wrong that is not apparent with your config.
I would try the following:
delete this two lines from your org.ops4j.pax.logging.cfg
(shown above):
Then restart openhab.
P.S: I tested it on my “OH2 test machine”, and it creates a separate logfile.
I had a similar question and applied your hints and it works for me
I’ve missed all these replies. Sorry guys. But thanks for the suggestions! Somehow I solved the problem, but don’t remember how right now
This is the current config in case anyone’s interested:
# Verisure Logger
log4j2.logger.VERISURE.name = org.openhab.binding.verisure
log4j2.logger.VERISURE.level = DEBUG
log4j2.logger.VERISURE.additivity = false
log4j2.logger.VERISURE.appenderRefs = VERISURE
log4j2.logger.VERISURE.appenderRef.VERISURE.ref = VERISURE
log4j2.appender.VERISURE.name = VERISURE
log4j2.appender.VERISURE.type = RollingRandomAccessFile
log4j2.appender.VERISURE.fileName = ${openhab.logdir}/verisure.log
log4j2.appender.VERISURE.filePattern = ${openhab.logdir}/verisure.log.%i
log4j2.appender.VERISURE.immediateFlush = true
log4j2.appender.VERISURE.append = true
log4j2.appender.VERISURE.layout.type = PatternLayout
log4j2.appender.VERISURE.layout.pattern = %d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n
log4j2.appender.VERISURE.policies.type = Policies
log4j2.appender.VERISURE.policies.size.type = SizeBasedTriggeringPolicy
log4j2.appender.VERISURE.policies.size.size = 3MB
log4j2.appender.VERISURE.strategy.type = DefaultRolloverStrategy
log4j2.appender.VERISURE.strategy.max = 30
Looks like I just made it uppercase… But that is not how I have it for other bindings so don’t know why it didn’t work for this one.
