Simple rule - when one switch is turned on - turn on the bathroom light
If someone could sanitize the below - i would be grateful
---the rule---
rule "Slave_1 On"
Item Slave_1 changed to ON
Bathroom.sendCommand(100)
rule "Slave_1 Off"
Item Slave_1 changed to OFF
Bathroom.sendCommand(0)
---Items---
Switch Slave_1 "Slave 1 [%d %%]"
{channel="rfxcom:lighting5:41f5363c_16060396_13:command"}
Dimmer Bathroom "Bathroom [%d %%]" (Alights) [ "Lighting" ]
{channel="zwave:device:6f409fa7:node3:command",
channel="zwave:device:6f409fa7:node3:switch_dimmer1",
channel="zwave:device:6f409fa7:node3:sensor_power1",
channel="zwave:device:6f409fa7:node3:meter_kwh1",
channel="zwave:device:6f409fa7:node3:meter_watts1",
channel="zwave:device:6f409fa7:node3:alarm_general1"}
There is a whole lot that can go wrong here. Is Slave_1 changing state? Check events.log to verify.
Is the Rule triggering? Add logging statements to the Rules and watch openahb.log to verify.
I don’t see anything wrong with these rules. The only thing that is slightly wrong is [%d %%] makes no sense for a Switch. Do you have any errors in openhab.log?
Hi - thanks for your reply, no i do not see the rule triggering - all i see if the events.log is the below :
2019-01-31 22:52:32.670 [vent.ItemStateChangedEvent] -
rfxcom_lighting5_41f5363c_16058678_13_command changed from OFF to ON
2019-01-31 22:52:32.705 [vent.ItemStateChangedEvent] - rfxcom_lighting5_41f5363c_16058678_13_contact changed from CLOSED to OPEN
I also tried the below that still did not trigger the rule:
rule "slaveWork"
Item Slave_1 received command ON or
Item Slave_1 received update On
Bathroom.sendCommand(ON)
Could you let me know how to add the rule logging?
Ah good spot - yep [%d %%] is not needed (think i had it set up as a dimmer in the past).
No errors seen in openhab.log unfortunately.
If your Item Slave_1 is not changing state then your rule won’t run. You need to look at that Item and its binding. The Item rfxcom channel and the event log you’ve shown us don’t match, were they supposed to?
