- Platform information:
- Hardware: _CPUArchitecture/RAM/storage Rasberry pi
- OS: _what OS is used and which version openhabian
- openHAB version: 2.5.0.M1
- Issue of the topic: please be detailed explaining your issue
I cant control the light in openhab. EspMilightHub I used this guide https://github.com/Skinah/EspMilightHub
The webinterface for the ESPmilight is working fine. I can control the lights with the webinttreface
This is my item file
Switch GF_LivingRoom_Light_s "Licht schakelaar" <light> (GF_LivingRoom, gLight) ["Lighting", "Switchable"] {channel="espmilighthub:rgb_cct:AB296F32:level"}
This is the log file
2019-07-11 10:04:27.627 [INFO ] [b.handler.EspMilightHubBridgeHandler] - Sucessfully subscribed to milight/states/#
2019-07-11 10:04:27.647 [DEBUG] [b.handler.EspMilightHubBridgeHandler] - * Recieved the following new Milight state:milight/states/0x0/rgb_cct/2 : {"state":"ON","level":100,"hue":354,"saturation":100,"bulb_mode":"color"}
2019-07-11 10:04:27.654 [DEBUG] [b.handler.EspMilightHubBridgeHandler] - * Recieved the following new Milight state:milight/states/0x59B6/rgb_cct/1 : {"state":"OFF","mode":0,"bulb_mode":"scene"}
2019-07-11 10:04:27.668 [TRACE] [b.handler.EspMilightHubBridgeHandler] - Processing new incoming MQTT message to update Openhab's controls.
2019-07-11 10:04:27.673 [TRACE] [b.handler.EspMilightHubBridgeHandler] - Message ={"state":"ON","level":100,"hue":354,"saturation":100,"bulb_mode":"color"}
2019-07-11 10:04:27.677 [TRACE] [b.handler.EspMilightHubBridgeHandler] - globeType =rgb_cct
2019-07-11 10:04:27.681 [TRACE] [b.handler.EspMilightHubBridgeHandler] - remoteCode =0x0
2019-07-11 10:04:27.684 [TRACE] [b.handler.EspMilightHubBridgeHandler] - remoteGroupID =2
2019-07-11 10:04:27.688 [TRACE] [b.handler.EspMilightHubBridgeHandler] - Chan Prefix =espmilighthub:rgb_cct:2c48b9aa:0x02:
2019-07-11 10:04:27.691 [TRACE] [b.handler.EspMilightHubBridgeHandler] - bulbState =ON
2019-07-11 10:04:27.694 [TRACE] [b.handler.EspMilightHubBridgeHandler] - bulbLevel =100
2019-07-11 10:04:27.737 [TRACE] [b.handler.EspMilightHubBridgeHandler] - Processing new incoming MQTT message to update Openhab's controls.
2019-07-11 10:04:27.740 [TRACE] [b.handler.EspMilightHubBridgeHandler] - Message ={"state":"OFF","mode":0,"bulb_mode":"scene"}
2019-07-11 10:04:27.744 [TRACE] [b.handler.EspMilightHubBridgeHandler] - globeType =rgb_cct
2019-07-11 10:04:27.747 [TRACE] [b.handler.EspMilightHubBridgeHandler] - remoteCode =0x59B6
2019-07-11 10:04:27.750 [TRACE] [b.handler.EspMilightHubBridgeHandler] - remoteGroupID =1
2019-07-11 10:04:27.754 [TRACE] [b.handler.EspMilightHubBridgeHandler] - Chan Prefix =espmilighthub:rgb_cct:2c48b9aa:0x59B61:
2019-07-11 10:04:27.757 [TRACE] [b.handler.EspMilightHubBridgeHandler] - bulbState =OFF
2019-07-11 10:04:27.760 [TRACE] [b.handler.EspMilightHubBridgeHandler] - bulbLevel =
Errors in log file
> 2019-07-11 10:04:17.028 [ERROR] [ipse.smarthome.io.mqttembeddedbroker] - bundle org.eclipse.smarthome.io.mqttembeddedbroker:0.11.0.oh250M1 (227)[org.eclipse.smarthome.io.mqttembeddedbroker.internal.EmbeddedBrokerServiceImpl(229)] : The activate method has thrown an exception
The milight globe ab296f32 is using lowercase for the remote code when the hub needs UPPERCASE
How do i change this?
