Hi all,
I could use some help with this. I am trying to install/activate a 1.0 binding that the author says works for 2.0 as well. I have legacy binding on. I have dropped the json file into the addons folder. It does not show in the Paper UI, but in the karaf console, under bundle:list, it does how as “Installed” – all other ones show as “active” that were installed on the UI.
So, am I missing something to get this active? Thank you.
I should mention, this is for a Russound RNET device.
I have not (I am very new with this). I dont see any binding specific files in the system folder or elsewhere. Should they be created on startup? Or I new to create the files?
I think, as you installed it manually, you will have to do the config also manually
As this is a OH1 Binding, you will have to create a file /etc/openhab2/services/russound.cfg with the content
################################# Russound ############################################
# Enter the host IP of the computer which has exposed the RNET serial communication via the
# python script tcp_serial_redirect.py
# eg. python ./tcp_serial_redirect.py -b 19200 /dev/ttyUSB0
# this script effectively makes the serial connection (via /dev/ttyUSB0 port on my linux)
# available on the internal network, uses port 7777 by default.
# This allows one to have the serial connection to the Russound devices on a different computer
# than the Openhab executable
# Enter the port(optional) (7777) and host ip
host=192.168.1.30
#port=7777
Of course you have to change the ip to your russound ip.
Maybe this doesn’t work as expected, then you can try the other file etc/openhab2/services/openhab.cfg
You will have to write a russound: in front of any option referring to russound, say
russound:host=192.168.1.30
#russound:port=7777
If changing the port, delete the # as this is the comments sign.
Thank you for the excellent instructions, but they are not working for me. I tried both .cfg files and restarted openhab. Once done, should the binding show on the paper UI?
Note, I am using iTach for serial connection, as i was not able to get it set up with USB to serial on Pi.
I believe that you mean the *.jar file into the addons (/usr/share/openhab2/addons) folder… right? (not json)
If the binding status shows up as “Installed” and not “Active” it is usually due to some unresolved dependency.
Try the bundle:resolve <id> and/or bundle:requirements <id> commands in the karaf console (maybe this will help)
Manually installed bindings do not show up in the Paper UI list of Add-Ons
Now, bear with me, i restarted and go into paper UI, but still cant add the Russound device as a thing / i have that attached to a iTach, which i have added that binding. Any further clues?
Ok, i had kept in place the russound.cfg file. The official one is for Rio products, and this one uses RNET protocol. Hopefully it will be updated soon. But for now I want see if OpenHAB can control my russound. I have had a heck of a time, probably b/c i am new to all this.
