Issue of the topic: After installation, openhab won’t run
I’ve tried installing openHAB 2.3.0 manually using both zulu-10 and zulu-11. I have also tried installing using Chocolaty which installed jre1.8.0_181.
I get the following error message:
C:\ProgramData\chocolatey\lib\openhab\tools>start.bat
Launching the openHAB runtime...
-Djava.endorsed.dirs=C:\Program Files\Zulu\zulu-10\jre\lib\endorsed;C:\Program Files\Zulu\zulu-10\lib\endorsed;C:\ProgramData\chocolatey\lib\openhab\tools\runtime\bin\..\lib\endorsed is not supported. Endorsed standards and standalone APIs
in modular form will be supported via the concept of upgradeable modules.
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
Note that the error message is the same regardless of which java installation I point the JAVA_HOME environment variable to. I’d like to try openHAB out, but I can’t.
Does anyone know what’s going on here and how I can get it to install?
As I pointed out in the original post, one of my attempts was with Chocolaty, which installed Java 8. Even then, and with changing my JAVA_HOME system environment variable to point to the Java 8 location, I still got the exact same message as above.
JAVA_HOME is pointing to the Java 8 installation. It would be helpful if someone can suggest where to look to correct this.
I started with the standard windows install, but that didn’t work because I installed Zulu-10. Many of the OpenHab docs are pretty old, and so when I read this about the prerequisites:
As for now, a pre-release Java 9 installation is not recommended and is not yet supported by openHAB 2.
I just assumed that was out of date since we’re no longer at Java 9 pre-release, but actually at fully released Java 10. It would be helpful to clarify the documentation to state that no Java version above 8 should be used.
In any event, I went the choco route after the standard install didn’t work.
