Is there someone sending mail through gmail smtp in OH2?
I’m using the same settings I did in OH1 hostname=smtp.gmail.com
port=587
username=******
password=******
tls=true
I’ve double and triple checked the username and password.
I’ve removed all import org.openhab… from the *.rules file.
Anyone with an idea (or that can decrypt the error message)?
I get the following error message
2016-12-17 14:04:56.996 [ERROR] [rg.openhab.action.mail.internal.Mail] - Could not send e-mail to ‘myemail@gmail.com’.
org.apache.commons.mail.EmailException: Sending the email to the following server failed : smtp.gmail.com:587
at org.apache.commons.mail.Email.sendMimeMessage(Email.java:1421)
at org.apache.commons.mail.Email.send(Email.java:1448)
at org.openhab.action.mail.internal.Mail.sendMail(Mail.java:157)
at org.openhab.action.mail.internal.Mail.sendMail(Mail.java:89)
at org.openhab.action.mail.internal.Mail.sendMail(Mail.java:67)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_111]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_111]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_111]
at java.lang.reflect.Method.invoke(Method.java:498)[:1.8.0_111]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1085)[143:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1060)[143:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046)[143:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991)[143:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:114)[127:org.eclipse.smarthome.model.script:0.9.0.201612091054]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:901)[143:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:864)[143:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:223)[143:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203)[143:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446)[143:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227)[143:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:459)[143:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:243)[143:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189)[143:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.smarthome.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:77)[128:org.eclipse.smarthome.model.script.runtime:0.9.0.201612091054]
at org.eclipse.smarthome.model.script.engine.ScriptExecutionThread.run(ScriptExecutionThread.java:42)[127:org.eclipse.smarthome.model.script:0.9.0.201612091054]
Caused by: javax.mail.MessagingException: Could not connect to SMTP host: smtp.gmail.com, port: 587;
nested exception is:
java.net.SocketTimeoutException: connect timed out
at com.sun.mail.smtp.SMTPTransport.openServer(SMTPTransport.java:1934)
at com.sun.mail.smtp.SMTPTransport.protocolConnect(SMTPTransport.java:638)
at javax.mail.Service.connect(Service.java:317)
at javax.mail.Service.connect(Service.java:176)
at javax.mail.Service.connect(Service.java:125)
at javax.mail.Transport.send0(Transport.java:194)
at javax.mail.Transport.send(Transport.java:124)
at org.apache.commons.mail.Email.sendMimeMessage(Email.java:1411)
… 29 more
Caused by: java.net.SocketTimeoutException: connect timed out
at java.net.PlainSocketImpl.socketConnect(Native Method)[:1.8.0_111]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)[:1.8.0_111]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)[:1.8.0_111]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)[:1.8.0_111]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)[:1.8.0_111]
at java.net.Socket.connect(Socket.java:589)[:1.8.0_111]
at com.sun.mail.util.SocketFetcher.createSocket(SocketFetcher.java:286)
at com.sun.mail.util.SocketFetcher.getSocket(SocketFetcher.java:231)
at com.sun.mail.smtp.SMTPTransport.openServer(SMTPTransport.java:1900)
… 36 more
I’m running exactly the same setup parameters as I did with OH1 (identical to watou’s except that the mail.cfg file doesn’t include the ‘mail:’ part).
The OH1 have successfully been sending at least one mail per day for the past two years so there is no problems having anything going out on port 587 from the router. Don’t know if there could be something blocking openhab from accessing the port internally on the odroid. No idea what that would be though. It’s a fresh install of the ubuntu 16.04 minimalistic image and I’ve added nothing that should block the port as far as I know.
I’ve tried different accounts and also different service suppliers without result. Also tried SSH instead of TLS but that changes nothing.
Something is definitely up with openHAB though. After playing around I’m back to my OH1 setup with hostname=smtp.gmail.com
port=587
username=******
password=******
tls=true
But even after I power cycled the unit the port is listed as 465 in the ERROR output.
Neither 465 nor SSH can be found in the jsondb. I deleted everything from my mail.cfg file (except the five lines above) just to be certain there isn’t anything fish going on there.
Where can this information be stored?!?! Where is openHAB digging up the port number from. Now I’m really lost!!
2016-12-19 20:54:32.705 [ERROR] [rg.openhab.action.mail.internal.Mail] - Could not send e-mail to ‘myemail@gmail.com’.
org.apache.commons.mail.EmailException: Sending the email to the following server failed : smtp.gmail.com:465
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:114)[127:org.eclipse.smarthome.model.script:0.9.0.201612171108]
at org.eclipse.smarthome.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:77)[128:org.eclipse.smarthome.model.script.runtime:0.9.0.201612171108]
at org.eclipse.smarthome.model.script.engine.ScriptExecutionThread.run(ScriptExecutionThread.java:42)[127:org.eclipse.smarthome.model.script:0.9.0.201612171108]
Caused by: javax.mail.MessagingException: Could not connect to SMTP host: smtp.gmail.com, port: 465;
… 29 more
at sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:668)[:1.8.0_111]
at com.sun.mail.util.SocketFetcher.getSocket(SocketFetcher.java:205)
… 36 more
