- Platform information:
- Hardware: _Dual Core E7400
- OS: Windows 10
- Java Runtime Environment: _ Oracle
After several attempts at trying to get the system variable to stick. I got a diffrent error message “Launching the openHAB runtime…
WARNING: Running Karaf on a Java HotSpot Client VM because server-mode is not available.
Install Java Developer Kit to fix this.
For more details see http://java.sun.com/products/hotspot/whitepaper.html#client
The system cannot find the path specified.”
So then i uninstalled oracle and tried to install Zulu, using the SE8 file, because it was the only one that still had a 32 bit version, and that’s what the instructions say.
So I unziped the file, like the other instructions say, and tried to do a checksum on the msi file, like the instructions say… Except that there is NO msi file in the download.
and so here i am
update: reinstalled oracle 8 using developers kit, tried to run the start.bat and got the original message
"C:\openHAB2>start.bat
JAVA_HOME is not valid: “C:\Program Files (x86)\Java\jre1.8.0_151\bin\java.exe”
The system cannot find the batch label specified - END
karaf.bat: JAVA_HOME is not valid: “C:\Program Files (x86)\Java\jre1.8.0_151\bin\java.exe”
that’s where the java is installed, am i supposed to use the exact variable that’s in the setup instructions? Because i couldn’t get that to work either
