Hi everyone,
I am new to openHAB2 and tried the last week to get my openHAB2 (running new newest Version from cloudbees on a raspberry Pi3) with Homematic CCU2 working. I am not using Homegear. I was following a few different tutorials using the Eclipse Smarthome Designer and the documantary on github.
But I have a few troubles with it:
- I can connect openhab2 with my CCU2 via Paper UI (status online), but no item or any of my devices will be found. And the .thing file created via SmarthomeDesigner (after I deleted the homematic bridge) doesn’t work either.
My homematic.thing:
Bridge homematic:bridge:ccu [ gatewayAddress="192.168.***.***"]{
Thing HM-LC-Sw2-FM LEQ0**** "Licht Thomas" @ "Thomas"
Thing HM-LC-Sw2-FM MEQ*** "Licht Eesszimmer" @ "Esszimmer"
- I tried to create a sitemap with following code in my first.sitemap, but there is no frame in my Paper UI:
sitemap Home label="Zuhause" {
Frame label="Gruppen" {
Group item=gLicht
Group item=gThomas
Group item=gEsszimmer
Frame label="Homematic" {
Switch item=licht_thomas
Switch item=licht_esszimmer
- I created a first.items and in Paper UI the items are visible but I am not able to switch anything. There is no connection to the CCU2
My first.items:
Group gLicht
Group gThomas
Group gEsszimmer
Switch licht_thomas "Thomas Licht" <light> (gLicht, gThomas) ["Lighting"] {channel="homematic:HM-LC-Sw2-FM:ccu:LEQ*****:1#PRESS_SHORT"}
Switch licht_esszimmer "Thomas Esszimmer" <light> (gLicht, gEsszimmer) ["Lighting"] {channel="homematic:HM-LC-Sw2-FM:ccu:MEQ******:1#PRESS_SHORT"}
My Echo Dot finds the two switches with Hue_Emulation Service.
Any futher google research was unsuccessful.
What am I doing wrong?
Thank you all for your help!
