I just bought this device:
Z-Wave Philio 4-in-1 Sensor, PHI_PST02-1A
After including it with my Aeotec z-stick, it is discovered as new thing. I can see its options in Paper UI and Habmin, BUT the device ist not accessable:
Status: UNINITIALIZED - HANDLER_MISSING_ERROR
Excluding and re-including did not help.
The Z-Wave-Stick is fine as I added another smoke sensor today which just works fine.
I usually include devices via Paper UI und configure them via .rules and .items. I rarely use HABmin, mainly to rename devices and calibrate rollershutters.
This is an excerpt from the log entry:
2017-08-03 15:34:44.377 [hingStatusInfoChangedEvent] - ‘zwave:device:7831ed67:node15’ changed from UNINITIALIZED to INITIALIZING
2017-08-03 15:34:44.402 [ConfigStatusInfoEvent ] - ConfigStatusInfo [configStatusMessages=[]]
2017-08-03 15:34:44.404 [hingStatusInfoChangedEvent] - ‘zwave:device:7831ed67:node15’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2017-08-03 15:34:44.410 [hingStatusInfoChangedEvent] - ‘zwave:device:7831ed67:node15’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2017-08-03 15:34:44.415 [ThingUpdatedEvent ] - Thing ‘zwave:device:7831ed67:node15’ has been updated.
2017-08-03 15:34:44.429 [hingStatusInfoChangedEvent] - ‘zwave:device:7831ed67:node15’ changed from ONLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
I added the thing in PaperUI, activated the channels in PaperUI und addes the following lines in .items to test general functionality:
Number Tuer_Flur_ba “Türsensor Flur Batterie [%d %%]” (EG_Flur, gBatterien) { channel=“zwave:device:7831ed67:node15:battery-level” }
Number Tuer_Flur_te “Türsensor Flur Temperatur” (Wetter, EG_Flur, gKlima, gBatterien) { channel=“zwave:device:7831ed67:node15:sensor_temperature” }
