I’ve been trying to experiment with the next-gen rule engine, and followed the python instructions here. But nothing seems to happen - no errors, no log entries - nothing. I’ve restarted openHAB and the PC several times to no avail.
The automation directory is in place as required. The next-gen rule engine add-on is installed. EXTRA_JAVA_OPTS is modified, and all the other steps followed.
I’d be grateful for any pointers - even just an idea of how to debug this would be great!
Currently, the easiest way set this up is to use the beta bundle…
I am testing two bundles now… one for Jython and another one for the libraries. I hope to have these out this weekend and with any luck they will get included in a 2.5 release.
If you are not seeing any log entries, I’d guess that you probably do not have the logging setup properly. What do you see after running log:get in the console?
Nope… looks like you do not have the rule engine installed. You can add it through Paper UI. What you see there is the beta Jython bundle, which has a dependency on the rule engine, so it can’t start.
Hi Guys, I am having the same issue. I have recently updated to a Pi4 and i’m having some trouble getting the rule engine to work. I copied the ‘automation’ folder over into the directory and have installed the rule engine but none of the rules come up in the paper UI. any ideas???
I’ll be happy to help you, but since your problem appears different than the OP’s, please open your own topic to discuss the issue you are having. In your topic, clearly document what steps you took to install Jython and the helper libraries.
