Can't remove Linked Item from Thing
I swapped locations for a couple of my Wemo Bulbs and thought I could change their respective configurations in PaperUI to reflect their new uses, but I’m finding that I can’t remove the previous linked item from either Thing. Should I delete the Things and rebuild them. or is there a better way? If I delete them, will they reappear in the Inbox? I’m comfortable working with the Karaf console, if there a way to do it there.
http://docs.openhab.org/administration/console.html
Try it via Console
smarthome:links
Usage: smarthome:links list - lists all links
Usage: smarthome:links addChannelLink - links an item with a channel
Usage: smarthome:links removeChannelLink - unlinks an item with a channel
Usage: smarthome:links clear - removes all managed links
Thanks for the reply, but when I try to remove the link, I get this error:
Could not remove link LRWindowLight_Brightness -> wemo:MZ100:Bridge-1_0-231551B01006E7:94103EA2B278A1A1:brightness
Here’s the command:
smarthome:links removeChannelLink LRWindowLight_Brightness wemo:MZ100:Bridge-1_0-231551B01006E7:94103EA2B278A1A1:brightness
I even restarted OH2, but no luck.
Any ideas?
How did you create the items?
Automatically created by smart mode , created from within PaperUI, created by an items file.
In my items file.
In this case you ned to change them in the items file!
PaperUI can’t manipulate this file.
Thank you, it works now.
http://docs.openhab.org/configuration/index.html#comparison
