Hey,
I had to restore my device from a backup and since then I can’t start the openhab3 container anymore, it always ends with Exited (127)
Error log:
$ sudo docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
$ sudo docker ps -a
728f4ccb5234 openhab/openhab:3.1.0 "/entrypoint gosu op…" 2 weeks ago Exited (127) 33 seconds ago openhab
$ sudo docker start 728f4ccb5234
Error response from daemon: OCI runtime create failed: container_linux.go:380: starting container process caused: exec: "/entrypoint": stat /entrypoint: no such file or directory: unknown
Error: failed to start containers: 728f4ccb5234
and when I tried to rebuild with different name I get:
$ sudo docker run --name openhab-2 --net=host -v /etc/localtime:/etc/localtime:ro -v /etc/timezone:/etc/timezone:ro -v openhab_addo
ns:/openhab/addons -v openhab_conf:/openhab/conf -v openhab_userdata:/openhab/userdata -e "EXTRA_JAVA_OPTS=-Duser.timezone=Europe/Berlin" -d --restart=always openhab/openhab:3.1.0
docker: Error response from daemon: mkdir /var/lib/docker/btrfs/subvolumes/9effef716acffa6db020bf42f8a12bff549519d9d36cf73ad9f6d7d8137a3f28-init/etc: permission denied.
See 'docker run --help'.```
rlkoshak
(Rich Koshak)
August 23, 2021, 9:44pm
2
What is in openhab.log? What do you see if you run docker logs -f openhab
$ sudo docker logs -f openhab
+ IFS='
+ '[' limited = unlimited ']'
+ rm -f /openhab/runtime/instances/instance.properties
+ rm -f /openhab/userdata/tmp/instances/instance.properties
+ NEW_USER_ID=9001
+ NEW_GROUP_ID=9001
+ echo 'Starting with openhab user id: 9001 and group id: 9001'
+ id -u openhab
++ getent group 9001
Create group openhab with id 9001
+ '[' -z '' ']'
+ echo 'Create group openhab with id 9001'
+ groupadd -g 9001 openhab
Create user openhab with id 9001
+ echo 'Create user openhab with id 9001'
+ adduser -u 9001 --disabled-password --gecos '' --home /openhab --gid 9001 openhab
Warning: The home dir /openhab you specified already exists.
Adding user `openhab' ...
Adding new user `openhab' (9001) with group `openhab' ...
adduser: Warning: The home directory `/openhab' does not belong to the user you are currently creating.
The home directory `/openhab' already exists. Not copying from `/etc/skel'.
+ groupadd -g 14 uucp2
+ groupadd -g 16 dialout2
+ groupadd -g 18 dialout3
+ groupadd -g 32 uucp3
+ groupadd -g 997 gpio
+ adduser openhab dialout
Adding user `openhab' to group `dialout' ...
Adding user openhab to group dialout
Done.
+ adduser openhab uucp
Adding user `openhab' to group `uucp' ...
Adding user openhab to group uucp
Done.
+ adduser openhab uucp2
Adding user `openhab' to group `uucp2' ...
Adding user openhab to group uucp2
Done.
+ adduser openhab dialout2
Adding user `openhab' to group `dialout2' ...
Adding user openhab to group dialout2
Done.
+ adduser openhab dialout3
Adding user `openhab' to group `dialout3' ...
Adding user openhab to group dialout3
Done.
+ adduser openhab uucp3
Adding user `openhab' to group `uucp3' ...
Adding user openhab to group uucp3
Done.
+ adduser openhab gpio
Adding user `openhab' to group `gpio' ...
Adding user openhab to group gpio
Done.
+ initialize_volume /openhab/conf /openhab/dist/conf
+ volume=/openhab/conf
+ source=/openhab/dist/conf
++ ls -A /openhab/conf
+ '[' -z 'html
icons
items
persistence
rules
scripts
services
sitemaps
sounds
things
transform' ']'
+ initialize_volume /openhab/userdata /openhab/dist/userdata
+ volume=/openhab/userdata
+ source=/openhab/dist/userdata
++ ls -A /openhab/userdata
+ '[' -z 'etc
logs
tmp' ']'
++ cmp /openhab/userdata/etc/version.properties /openhab/dist/userdata/etc/version.properties
+ '[' '!' -z ']'
+ chown -R openhab:openhab /openhab
+ sync
+ '[' -d /etc/cont-init.d ']'
+ sync
+ '[' false == false ']'
++ IFS=' '
++ echo gosu openhab tini -s ./start.sh
+ '[' 'gosu openhab tini -s ./start.sh' == 'gosu openhab tini -s ./start.sh' ']'
+ command=($@ server)
+ exec gosu openhab tini -s ./start.sh server
Launching the openHAB runtime...
+ IFS='
+ NEW_USER_ID=9001
+ NEW_GROUP_ID=9001
+ id -u openhab
+ '[' -z 'html
icons
items
misc
persistence
rules
scripts
services
sitemaps
sounds
things
transform' ']'
+ '[' -z 'cache
config
etc
jsondb
logs
persistence
secrets
tmp' ']'
+ '[' '!' -z ']'
+ sync
+ sync
++ IFS=' '
+ IFS='
+ NEW_USER_ID=9001
+ NEW_GROUP_ID=9001
+ id -u openhab
+ '[' -z 'html
icons
items
misc
persistence
rules
scripts
services
sitemaps
sounds
things
transform' ']'
+ '[' -z 'cache
config
etc
jsondb
logs
persistence
secrets
tmp' ']'
+ '[' '!' -z ']'
+ sync
+ sync
++ IFS=' '
+ IFS='
+ NEW_USER_ID=9001
+ NEW_GROUP_ID=9001
+ id -u openhab
+ '[' -z 'html
icons
items
misc
persistence
rules
scripts
services
sitemaps
sounds
things
transform' ']'
+ '[' -z 'cache
config
etc
jsondb
kar
logs
persistence
secrets
tmp' ']'
+ '[' '!' -z ']'
+ sync
+ sync
++ IFS=' '
+ IFS='
+ NEW_USER_ID=9001
+ NEW_GROUP_ID=9001
+ id -u openhab
+ '[' -z 'html
icons
items
misc
persistence
rules
scripts
services
sitemaps
sounds
things
transform' ']'
+ '[' -z 'cache
config
etc
jsondb
kar
logs
persistence
secrets
tmp' ']'
+ '[' '!' -z ']'
+ sync
+ sync
++ IFS=' '
+ IFS='
+ NEW_USER_ID=9001
+ NEW_GROUP_ID=9001
+ id -u openhab
+ '[' -z 'html
icons
items
misc
persistence
rules
scripts
services
sitemaps
sounds
things
transform' ']'
+ '[' -z 'cache
config
etc
jsondb
kar
logs
persistence
secrets
tmp' ']'
+ '[' '!' -z ']'
+ sync
+ sync
++ IFS=' '
+ IFS='
+ NEW_USER_ID=9001
+ NEW_GROUP_ID=9001
+ id -u openhab
+ '[' -z 'html
icons
items
misc
persistence
rules
scripts
services
sitemaps
sounds
things
transform' ']'
+ '[' -z 'cache
config
etc
jsondb
kar
logs
persistence
secrets
tmp' ']'
+ '[' '!' -z ']'
+ sync
+ sync
++ IFS=' '
+ IFS='
+ NEW_USER_ID=9001
+ NEW_GROUP_ID=9001
+ id -u openhab
+ '[' -z 'html
icons
items
misc
persistence
rules
scripts
services
sitemaps
sounds
things
transform' ']'
+ '[' -z 'cache
config
etc
jsondb
kar
logs
persistence
secrets
tmp' ']'
+ '[' '!' -z ']'
+ sync
+ sync
++ IFS=' '
+ IFS='
+ NEW_USER_ID=9001
+ NEW_GROUP_ID=9001
+ id -u openhab
+ '[' -z 'html
icons
items
misc
persistence
rules
scripts
services
sitemaps
sounds
things
transform' ']'
+ '[' -z 'cache
config
etc
jsondb
kar
logs
persistence
secrets
tmp' ']'
+ '[' '!' -z ']'
+ sync
+ sync
++ IFS=' '
+ IFS='
+ NEW_USER_ID=9001
+ NEW_GROUP_ID=9001
+ id -u openhab
+ '[' -z 'html
icons
items
misc
persistence
rules
scripts
services
sitemaps
sounds
things
transform' ']'
+ '[' -z 'cache
config
etc
jsondb
kar
logs
persistence
secrets
tmp' ']'
+ '[' '!' -z ']'
+ sync
+ sync
++ IFS=' '
+ IFS='
+ NEW_USER_ID=9001
+ NEW_GROUP_ID=9001
+ id -u openhab
+ '[' -z 'html
icons
items
misc
persistence
rules
scripts
services
sitemaps
sounds
things
transform' ']'
+ '[' -z 'cache
config
etc
jsondb
kar
logs
persistence
secrets
tmp' ']'
+ '[' '!' -z ']'
+ sync
+ sync
++ IFS=' '
rlkoshak
(Rich Koshak)
August 24, 2021, 1:39pm
4
And openhab.log? It’s really tiresome to ask for the same information more than once.
The docker logs shows that openHAB is starting. After that everything is written to openhab.log.
