For some reason, when I created the links, I used the simple setup. The number I get without trying to get rid of the extra digits for example is 12.7665 F. I’d much rather have this rounded to just 13. However when I try the number formatting above for current temp I get a blank. I am thinking because the auto links created items for that specific group as number:temperature. Is there a way to format this to no decimals? Also the barometric pressure is 15 decimal places long and does not work with the supplied code. This is formatted as Number:Pressure. In the widget I just get -NaN. Could someone point me in the right direction?
Hmm, would it be possible in angularjs to split the degree f from the result and then perform the number:0? Im extremely new to java/angularjs. Could you or anyone else provide a code sample for this?
Something like {{temp | split:" ":0 | number:0}}degree f
