I’m trying to set the initial value of a DateTime Item (named Opening1), but I’m failing, WHY???
I have this in a rule:
logInfo("OpeningTimes", "Opening1 = {}", Opening1) Opening1.postUpdate(now)
and I’m getting this:
12:08:56.755 [INFO ] [.smarthome.model.script.OpeningTimes] - Opening1 = Opening1 (Type=DateTimeItem, State=NULL, Label=null, Category=null)
12:08:56.771 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule Call Lambda: An error occured during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.postUpdate(org.eclipse.smarthome.core.items.Item,org.eclipse.smarthome.core.types.State) on instance: null
Why is the instance null, that should be the Item Opening1, which is logged in the line above???
