Hello Martin,
I’m just tagging onto this issue as I think I have the same problems with my HMIP-SWDO and all my new HmIP-eTRV-B radiator valves.
I have captured the TRACE/DEBUG log output. Maybe it helps to identify the issue:
- The eTRV log
2022-01-06 12:16:27.608 [DEBUG] [ommunicator.AbstractHomematicGateway] - Triggering values reload for device '00201D898CEFBE'
2022-01-06 12:16:27.608 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:0#OPERATING_VOLTAGE_STATUS' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.609 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:0#RSSI_DEVICE' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.610 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:0#BATTERY_TYPE' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.611 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:0#DELETE_DEVICE' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.612 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:0#RSSI' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.612 [DEBUG] [ommunicator.AbstractHomematicGateway] - Loading values for channel HmChannel[number=0,initialized=false] of device '00201D898CEFBE'
2022-01-06 12:16:27.613 [TRACE] [nal.communicator.client.XmlRpcClient] - Client XmlRpcRequest (port 2010):
<?xml version="1.0" encoding="ISO-8859-1"?>
<methodCall><methodName>getParamset</methodName>
<params><param><value>00201D898CEFBE:0</value></param><param><value>MASTER</value></param></params></methodCall>
2022-01-06 12:16:27.624 [TRACE] [nal.communicator.client.XmlRpcClient] - Client XmlRpcResponse (port 2010):
<?xml version="1.0" encoding="ISO-8859-1"?><methodResponse><params><param><value><struct><member><name>DAYLIGHT_SAVINGS_TIME</name><value><boolean>1</boolean></value></member><member><name>DUTYCYCLE_LIMIT</name><value><i4>180</i4></value></member><member><name>DST_START_DAY_OF_WEEK</name><value><i4>0</i4></value></member><member><name>DST_END_DAY_OF_WEEK</name><value><i4>0</i4></value></member><member><name>UTC_DST_OFFSET</name><value><i4>120</i4></value></member><member><name>DST_END_MONTH</name><value><i4>10</i4></value></member><member><name>CYCLIC_INFO_MSG_OVERDUE_THRESHOLD</name><value><i4>2</i4></value></member><member><name>LOCAL_RESET_DISABLED</name><value><boolean>0</boolean></value></member><member><name>DST_START_MONTH</name><value><i4>3</i4></value></member><member><name>ARR_TIMEOUT</name><value><i4>10</i4></value></member><member><name>UTC_OFFSET</name><value><i4>60</i4></value></member><member><name>CYCLIC_INFO_MSG</name><value><i4>1</i4></value></member><member><name>CYCLIC_INFO_MSG_DIS_UNCHANGED</name><value><i4>20</i4></value></member><member><name>DST_START_TIME</name><value><i4>120</i4></value></member><member><name>GLOBAL_BUTTON_LOCK</name><value><boolean>0</boolean></value></member><member><name>DISABLE_MSG_TO_AC</name><value><boolean>0</boolean></value></member><member><name>CYCLIC_INFO_MSG_DIS</name><value><i4>1</i4></value></member><member><name>ENABLE_ROUTING</name><value><boolean>1</boolean></value></member><member><name>DST_START_WEEK_OF_MONTH</name><value><i4>5</i4></value></member><member><name>LOW_BAT_LIMIT</name><value><double>2.2</double></value></member><member><name>DST_END_TIME</name><value><i4>180</i4></value></member><member><name>DST_END_WEEK_OF_MONTH</name><value><i4>5</i4></value></member></struct></value></param></params></methodResponse>
2022-01-06 12:16:27.627 [TRACE] [nal.communicator.client.XmlRpcClient] - Client XmlRpcRequest (port 2010):
<params><param><value>00201D898CEFBE:0</value></param><param><value>VALUES</value></param></params></methodCall>
2022-01-06 12:16:27.634 [TRACE] [nal.communicator.client.XmlRpcClient] - Client XmlRpcResponse (port 2010):
<?xml version="1.0" encoding="ISO-8859-1"?><methodResponse><params><param><value><struct><member><name>CONFIG_PENDING</name><value><boolean>0</boolean></value></member><member><name>DUTY_CYCLE</name><value><boolean>0</boolean></value></member><member><name>LOW_BAT</name><value><boolean>0</boolean></value></member><member><name>UNREACH</name><value><boolean>0</boolean></value></member><member><name>OPERATING_VOLTAGE_STATUS</name><value><i4>0</i4></value></member><member><name>RSSI_DEVICE</name><value><i4>-87</i4></value></member><member><name>OPERATING_VOLTAGE</name><value><double>3.1</double></value></member><member><name>UPDATE_PENDING</name><value><boolean>0</boolean></value></member></struct></value></param></params></methodResponse>
2022-01-06 12:16:27.636 [WARN ] [ommunicator.parser.GetParamsetParser] - Can't set value for datapoint '00201D898CEFBE:0#UPDATE_PENDING'
2022-01-06 12:16:27.637 [TRACE] [converter.type.AbstractTypeConverter] - Converting datapoint '00201D898CEFBE:0#RSSI' (dpType='INTEGER', dpUnit='dBm', dpValue='-87') with DecimalTypeConverter
2022-01-06 12:16:27.638 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:0#CONFIG_PENDING' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.639 [TRACE] [converter.type.AbstractTypeConverter] - Converting datapoint '00201D898CEFBE:0#CONFIG_PENDING' (dpType='BOOL', dpUnit='null', dpValue='false') with OnOffTypeConverter
2022-01-06 12:16:27.640 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:0#DELETE_DEVICE_MODE' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.641 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:0#INSTALL_TEST' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.641 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:0#OPERATING_VOLTAGE' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.642 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:0#DUTY_CYCLE' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.643 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:0#RSSI_PEER' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.644 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:0#LOW_BAT' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.644 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:0#UNREACH' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.645 [TRACE] [converter.type.AbstractTypeConverter] - Converting datapoint '00201D898CEFBE:0#UNREACH' (dpType='BOOL', dpUnit='null', dpValue='false') with OnOffTypeConverter
2022-01-06 12:16:27.646 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:0#FIRMWARE' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.647 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:0#SIGNAL_STRENGTH' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.648 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#ACTUAL_TEMPERATURE' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.649 [DEBUG] [ommunicator.AbstractHomematicGateway] - Loading values for channel HmChannel[number=1,initialized=false] of device '00201D898CEFBE'
2022-01-06 12:16:27.649 [TRACE] [nal.communicator.client.XmlRpcClient] - Client XmlRpcRequest (port 2010):
<params><param><value>00201D898CEFBE:1</value></param><param><value>MASTER</value></param></params></methodCall>
2022-01-06 12:16:27.681 [TRACE] [nal.communicator.client.XmlRpcClient] - Client XmlRpcResponse (port 2010):
<?xml version="1.0" encoding="ISO-8859-1"?><methodResponse><params><param><value><struct><member><name>P2_ENDTIME_THURSDAY_7</name><value><i4>1440</i4></value></member><member><name>P1_ENDTIME_MONDAY_12</name><value><i4>1440</i4></
--- Channel 1 parameters too large to fit in maximum message size - Removed ---
name><value><i4>300</i4></value></member></struct></value></param></params></methodResponse>
2022-01-06 12:16:27.691 [TRACE] [nal.communicator.client.XmlRpcClient] - Client XmlRpcRequest (port 2010):
<params><param><value>00201D898CEFBE:1</value></param><param><value>VALUES</value></param></params></methodCall>
2022-01-06 12:16:27.699 [TRACE] [nal.communicator.client.XmlRpcClient] - Client XmlRpcResponse (port 2010):
<?xml version="1.0" encoding="ISO-8859-1"?><methodResponse><params><param><value><struct><member><name>BOOST_TIME</name><value><i4>0</i4></value></member><member><name>PARTY_MODE</name><value><boolean>0</boolean></value></member><member><name>SET_POINT_TEMPERATURE</name><value><double>19.0</double></value></member><member><name>LEVEL_STATUS</name><value><i4>0</i4></value></member><member><name>QUICK_VETO_TIME</name><value><i4>0</i4></value></member><member><name>FROST_PROTECTION</name><value><boolean>0</boolean></value></member><member><name>SET_POINT_MODE</name><value><i4>1</i4></value></member><member><name>LEVEL</name><value><double>0.05</double></value></member><member><name>ACTUAL_TEMPERATURE_STATUS</name><value><i4>0</i4></value></member><member><name>SWITCH_POINT_OCCURED</name><value><boolean>0</boolean></value></member><member><name>VALVE_STATE</name><value><i4>4</i4></value></member><member><name>ACTIVE_PROFILE</name><value><i4>1</i4></value></member><member><name>WINDOW_STATE</name><value><i4>0</i4></value></member><member><name>ACTUAL_TEMPERATURE</name><value><double>19.7</double></value></member><member><name>BOOST_MODE</name><value><boolean>0</boolean></value></member></struct></value></param></params></methodResponse>
2022-01-06 12:16:27.703 [DEBUG] [converter.type.AbstractTypeConverter] - Converting datapoint '00201D898CEFBE:1#ACTUAL_TEMPERATURE' (dpType='FLOAT', dpUnit='°C', dpValue='19.7') with QuantityTypeConverter
2022-01-06 12:16:27.704 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#DURATION_VALUE' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.705 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#VALVE_STATE' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.706 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#LEVEL' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.707 [TRACE] [converter.type.AbstractTypeConverter] - Converting datapoint '00201D898CEFBE:1#LEVEL' (dpType='FLOAT', dpUnit='100%', dpValue='0.05') with PercentTypeConverter
2022-01-06 12:16:27.708 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#PARTY_TIME_END' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.709 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#CONTROL_DIFFERENTIAL_TEMPERATURE' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.710 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#BOOST_MODE' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.711 [TRACE] [converter.type.AbstractTypeConverter] - Converting datapoint '00201D898CEFBE:1#BOOST_MODE' (dpType='BOOL', dpUnit='null', dpValue='false') with OnOffTypeConverter
2022-01-06 12:16:27.712 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#ACTIVE_PROFILE' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.713 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#PARTY_MODE' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.713 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#PARTY_TIME_START' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.714 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#CONTROL_MODE' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.715 [TRACE] [converter.type.AbstractTypeConverter] - Converting datapoint '00201D898CEFBE:1#CONTROL_MODE' (dpType='INTEGER', dpUnit='null', dpValue='null') with DecimalTypeConverter
2022-01-06 12:16:27.716 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#ACTUAL_TEMPERATURE_STATUS' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.717 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#BOOST_TIME' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.718 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#VALVE_ADAPTION' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.718 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#SET_POINT_TEMPERATURE' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.719 [DEBUG] [converter.type.AbstractTypeConverter] - Converting datapoint '00201D898CEFBE:1#SET_POINT_TEMPERATURE' (dpType='FLOAT', dpUnit='°C', dpValue='19.0') with QuantityTypeConverter
2022-01-06 12:16:27.720 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#QUICK_VETO_TIME' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.721 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#WINDOW_STATE' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.722 [TRACE] [converter.type.AbstractTypeConverter] - Converting datapoint '00201D898CEFBE:1#WINDOW_STATE' (dpType='ENUM', dpUnit='null', dpValue='0') with StringTypeConverter
2022-01-06 12:16:27.723 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#SWITCH_POINT_OCCURED' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.724 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#PARTY_SET_POINT_TEMPERATURE' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.725 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#LEVEL_STATUS' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.726 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#DURATION_UNIT' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.727 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#FROST_PROTECTION' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.727 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#SET_POINT_MODE' from thing id '00201D898CEFBE'
2022-01-06 12:16:27.728 [DEBUG] [ommunicator.AbstractHomematicGateway] - Triggering values reload for device '0009DD898B667C'
Log output from HmIP-SWDO:
2022-01-06 12:16:29.703 [DEBUG] [ommunicator.AbstractHomematicGateway] - Triggering values reload for device '0000DD89AA7F3B'
2022-01-06 12:16:29.704 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HMIP-SWDO:3014F711A0001F58A9A717F7:0000DD89AA7F3B:0#UPDATE_PENDING' from thing id '0000DD89AA7F3B'
2022-01-06 12:16:29.704 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HMIP-SWDO:3014F711A0001F58A9A717F7:0000DD89AA7F3B:0#RSSI' from thing id '0000DD89AA7F3B'
2022-01-06 12:16:29.705 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HMIP-SWDO:3014F711A0001F58A9A717F7:0000DD89AA7F3B:0#SABOTAGE' from thing id '0000DD89AA7F3B'
2022-01-06 12:16:29.706 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HMIP-SWDO:3014F711A0001F58A9A717F7:0000DD89AA7F3B:0#OPERATING_VOLTAGE_STATUS' from thing id '0000DD89AA7F3B'
2022-01-06 12:16:29.706 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HMIP-SWDO:3014F711A0001F58A9A717F7:0000DD89AA7F3B:0#ERROR_CODE' from thing id '0000DD89AA7F3B'
2022-01-06 12:16:29.707 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HMIP-SWDO:3014F711A0001F58A9A717F7:0000DD89AA7F3B:0#SIGNAL_STRENGTH' from thing id '0000DD89AA7F3B'
2022-01-06 12:16:29.707 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HMIP-SWDO:3014F711A0001F58A9A717F7:0000DD89AA7F3B:0#UNREACH' from thing id '0000DD89AA7F3B'
2022-01-06 12:16:29.708 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HMIP-SWDO:3014F711A0001F58A9A717F7:0000DD89AA7F3B:0#FIRMWARE' from thing id '0000DD89AA7F3B'
2022-01-06 12:16:29.709 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HMIP-SWDO:3014F711A0001F58A9A717F7:0000DD89AA7F3B:0#LOW_BAT' from thing id '0000DD89AA7F3B'
2022-01-06 12:16:29.709 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HMIP-SWDO:3014F711A0001F58A9A717F7:0000DD89AA7F3B:0#INSTALL_TEST' from thing id '0000DD89AA7F3B'
2022-01-06 12:16:29.710 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HMIP-SWDO:3014F711A0001F58A9A717F7:0000DD89AA7F3B:0#OPERATING_VOLTAGE' from thing id '0000DD89AA7F3B'
2022-01-06 12:16:29.710 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HMIP-SWDO:3014F711A0001F58A9A717F7:0000DD89AA7F3B:0#RSSI_PEER' from thing id '0000DD89AA7F3B'
2022-01-06 12:16:29.711 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HMIP-SWDO:3014F711A0001F58A9A717F7:0000DD89AA7F3B:0#DELETE_DEVICE_MODE' from thing id '0000DD89AA7F3B'
2022-01-06 12:16:29.712 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HMIP-SWDO:3014F711A0001F58A9A717F7:0000DD89AA7F3B:0#CONFIG_PENDING' from thing id '0000DD89AA7F3B'
2022-01-06 12:16:29.712 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HMIP-SWDO:3014F711A0001F58A9A717F7:0000DD89AA7F3B:0#DUTY_CYCLE' from thing id '0000DD89AA7F3B'
2022-01-06 12:16:29.713 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HMIP-SWDO:3014F711A0001F58A9A717F7:0000DD89AA7F3B:0#DELETE_DEVICE' from thing id '0000DD89AA7F3B'
2022-01-06 12:16:29.713 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HMIP-SWDO:3014F711A0001F58A9A717F7:0000DD89AA7F3B:0#RSSI_DEVICE' from thing id '0000DD89AA7F3B'
2022-01-06 12:16:29.714 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HMIP-SWDO:3014F711A0001F58A9A717F7:0000DD89AA7F3B:1#STATE_CONTACT' from thing id '0000DD89AA7F3B'
2022-01-06 12:16:29.715 [DEBUG] [ommunicator.AbstractHomematicGateway] - Loading values for channel HmChannel[number=1,initialized=false] of device '0000DD89AA7F3B'
2022-01-06 12:16:29.715 [TRACE] [nal.communicator.client.XmlRpcClient] - Client XmlRpcRequest (port 2010):
<params><param><value>0000DD89AA7F3B:1</value></param><param><value>MASTER</value></param></params></methodCall>
2022-01-06 12:16:29.725 [TRACE] [nal.communicator.client.XmlRpcClient] - Client XmlRpcResponse (port 2010):
<?xml version="1.0" encoding="ISO-8859-1"?><methodResponse><params><param><value><struct><member><name>SAMPLE_INTERVAL</name><value><double>0.5</double></value></member><member><name>EVENT_DELAY_UNIT</name><value><i4>0</i4></value></member><member><name>EVENT_DELAY_VALUE</name><value><i4>0</i4></value></member><member><name>MSG_FOR_POS_B</name><value><i4>1</i4></value></member><member><name>ALARM_MODE_ZONE_6</name><value><boolean>0</boolean></value></member><member><name>MSG_FOR_POS_A</name><value><i4>2</i4></value></member><member><name>ALARM_MODE_ZONE_5</name><value><boolean>0</boolean></value></member><member><name>ALARM_MODE_ZONE_7</name><value><boolean>0</boolean></value></member><member><name>ALARM_MODE_ZONE_2</name><value><boolean>0</boolean></value></member><member><name>ALARM_MODE_ZONE_1</name><value><boolean>0</boolean></value></member><member><name>ALARM_MODE_TYPE</name><value><i4>0</i4></value></member><member><name>ALARM_MODE_ZONE_4</name><value><boolean>0</boolean></value></member><member><name>ALARM_MODE_ZONE_3</name><value><boolean>0</boolean></value></member></struct></value></param></params></methodResponse>
2022-01-06 12:16:29.728 [DEBUG] [ommunicator.parser.GetParamsetParser] - Can't set value for channel configuration datapoint '0000DD89AA7F3B:M_1#ALARM_MODE_ZONE_6'
2022-01-06 12:16:29.729 [DEBUG] [ommunicator.parser.GetParamsetParser] - Can't set value for channel configuration datapoint '0000DD89AA7F3B:M_1#ALARM_MODE_ZONE_5'
2022-01-06 12:16:29.729 [DEBUG] [ommunicator.parser.GetParamsetParser] - Can't set value for channel configuration datapoint '0000DD89AA7F3B:M_1#ALARM_MODE_ZONE_7'
2022-01-06 12:16:29.730 [DEBUG] [ommunicator.parser.GetParamsetParser] - Can't set value for channel configuration datapoint '0000DD89AA7F3B:M_1#ALARM_MODE_ZONE_2'
2022-01-06 12:16:29.730 [DEBUG] [ommunicator.parser.GetParamsetParser] - Can't set value for channel configuration datapoint '0000DD89AA7F3B:M_1#ALARM_MODE_ZONE_1'
2022-01-06 12:16:29.731 [DEBUG] [ommunicator.parser.GetParamsetParser] - Can't set value for channel configuration datapoint '0000DD89AA7F3B:M_1#ALARM_MODE_TYPE'
2022-01-06 12:16:29.732 [DEBUG] [ommunicator.parser.GetParamsetParser] - Can't set value for channel configuration datapoint '0000DD89AA7F3B:M_1#ALARM_MODE_ZONE_4'
2022-01-06 12:16:29.732 [DEBUG] [ommunicator.parser.GetParamsetParser] - Can't set value for channel configuration datapoint '0000DD89AA7F3B:M_1#ALARM_MODE_ZONE_3'
2022-01-06 12:16:29.733 [TRACE] [nal.communicator.client.XmlRpcClient] - Client XmlRpcRequest (port 2010):
<params><param><value>0000DD89AA7F3B:1</value></param><param><value>VALUES</value></param></params></methodCall>
2022-01-06 12:16:29.740 [TRACE] [nal.communicator.client.XmlRpcClient] - Client XmlRpcResponse (port 2010):
<?xml version="1.0" encoding="ISO-8859-1"?><methodResponse><params><param><value><struct><member><name>STATE</name><value><i4>0</i4></value></member></struct></value></param></params></methodResponse>
2022-01-06 12:16:29.742 [TRACE] [converter.type.AbstractTypeConverter] - Converting datapoint '0000DD89AA7F3B:1#STATE_CONTACT' (dpType='BOOL', dpUnit='null', dpValue='true') with OpenClosedTypeConverter
2022-01-06 12:16:29.744 [DEBUG] [ternal.handler.HomematicThingHandler] - Updating channel 'homematic:HMIP-SWDO:3014F711A0001F58A9A717F7:0000DD89AA7F3B:1#STATE' from thing id '0000DD89AA7F3B'
I’m currently running RaspiMatic 3.61.7.20211218 on RPI3 and OH3.2 but the issue also existed on OH3.1.
I migrated during the holidays from OH2.5 with MAX! valves and wall thermostats on Homegear. (no window contacts in this setup). I have re-used my items file to re-use my rules, but updated the CCU and device ID. It all seems to be working OK except for the log messages and the fact that I have schedule a “Reload All From Gateway” every 5 minutes to update the temperatures in OH.
Definitions in my items file are as follows:
// Living Radiator Thermostaat
Number LV1_verwarming_RSSI "RSSI [%d dBm]" <"signal-3"> (Verwarming_Living,RSSI_Group) {channel="homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:0#RSSI"}
Switch LV1_verwarming_Unreach "Onberijkbaar" <siren> (Verwarming_Living,Unreach_Group) {channel="homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:0#UNREACH"}
Switch LV1_verwarming_Pending "Config pending" <siren> (Verwarming_Living,Pending_Group) {channel="homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:0#CONFIG_PENDING"}
//Switch LV1_verwarming_Update "Update pending" <siren> (Verwarming_Living,Pending_Group) {channel="homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:0#UPDATE_PENDING"}
Number LV1_verwarming_SetTemp "Gevraagde Temperatuur [%.1f °C]" <Temperature> (Verwarming_Living,Heating_TargetTemps) {channel="homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#SET_POINT_TEMPERATURE"}
Number LV1_verwarming_ActTemp "Actuele Temperatuur [%.1f °C]" <Temperature> (Verwarming_Living,Heating_ActTemps) {channel="homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#ACTUAL_TEMPERATURE"}
Number LV1_verwarming_Valve "Ventiel Positie [%d %%]" <heating> (Verwarming_Living,Heating_ValveSettings) {channel="homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#LEVEL"}
Number LV1_verwarming_Mode "Bedrijf Type [%d]" <"heating-off"> (Verwarming_Living,Heating_OpModes) {channel="homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#CONTROL_MODE"}
Switch LV1_verwarming_BoostMode "Boost-Mode" <fire> (Verwarming_Living) {channel="homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#BOOST_MODE"}
String LV1_verwarming_WindowState "Raam Status" <window> (Verwarming_Living,Heating_WindowStates) {channel="homematic:HmIP-eTRV-B:3014F711A0001F58A9A717F7:00201D898CEFBE:1#WINDOW_STATE"}
Number LV1_verwarming_Preset "Gevraagde-Temperatuur Snelkeuze" <"heating-60"> (Verwarming_Living)
Number LV1_verwarming_PresetTemp "Gevraagde-Temperatuur Tijdprogramma [%.1f °C]" <line> (Verwarming_Living,Heating_TargetPresets)
String LV1_verwarming_Summary "Overzicht [%s]" <thermometer_red> (Verwarming_Living)
Hope this helps to find what’s happening.
Regards,
Richard
