Hi, sorry for asking such a basic question but I have G1 Aeotec Smart meter that I have set up as Node 2 in my Zwave network. I have configured it to send reports for the current Watts and accumulated kwH every minute. These meter values are coming through in the event.log and I can view and graph them using the habmin panel, paper UI, and the REST api pages, however when I try to create an item and sitemap using the zwave bindings, I never seem to get any values. It’s always zero, “-”, or some crazy large number. Is there a way to debug the zwave binding to understand why the actual values are not getting pulled even though I can see them habmin and the REST api?
A portion of my event.log is as follows:
2017-03-27 17:48:22.594 [ItemStateChangedEvent ] - zwave_device_7d36d8f0_node2_meter_watts changed from 2194.44 to 2558.64
2017-03-27 17:48:22.676 [ItemStateChangedEvent ] - zwave_device_7d36d8f0_node2_meter_kwh changed from 624.191 to 624.228
2017-03-27 17:49:22.603 [ItemStateChangedEvent ] - zwave_device_7d36d8f0_node2_meter_watts changed from 2558.64 to 2198.04
2017-03-27 17:49:22.676 [ItemStateChangedEvent ] - zwave_device_7d36d8f0_node2_meter_kwh changed from 624.228 to 624.266
My items file which tries to get these values for use in a sitemap looks like:
Number HEM_E1 "Power [%.2f W]" { zwave="2:command=METER, meter_scale=W" }
Number HEM_E2 "Acumulated [%.2f kWh]" { zwave="2:command=METER, meter_scale=E_kWh" }
I’ve tried all variations on the item definitions (2:0, 2:1, etc…)
and the sitemap is just.
Frame {
Text item=HEM_E1
Text item=HEM_E2
// Switch item=EReset
I’ve enabled zwave debugging but don’t see anything in the logs when I try to pull up my sitemap. Interestingly the default Classic and Basic UI’s give me an autogenerated pullright entry for the meter and I see both values correctly as well as the reset switch. The url for that is http://alarmpi:8080/classicui/app#_0002 vs http://alarmpi:8080/classicui/app?sitemap=power. Clearly the values are getting through someplace because I can see them in various places, so I must be missing something basic in creating the simple item and sitemap I really would like to be able to make my own sitemap for this so I can add additional information on the same page.
Thanks!
