Hi, I want to control my Samsung TV, my Denon receiver and my Skybox with the Amazon Echo by voice. For this I have a Pi with Openhab and a Logitech Harmony Hub to run.
To make it easy first, I just want to turn the Denon receiver on and off. The Denon receiver is defined as “Thing” with the id harmonyhub: device: HarmonyHub: 22028016.
rule “Denon on / off”
When
Item harmony_denon_power received command
switch (receivedCommand) {
case ON: harmony_denon.sendCommand (“PowerToggle”)
case OFF: harmony_denon.sendCommand (“PowerToggle”)
When I say “Alexa Denon on”, the Echo understands the command, but nothing happens. What I’m doing wrong?
Hi, yes if I use the switch over the browser everything works fine. But its still not working if I use it over the echo with “Denon on” or “Denon off”. The echo says OK if I use the command “Alexa Denon On or Off”, but the receiver still doesn’t turn on or off.
Any ideas?
