---> Package openhab2.noarch 0:2.5.6~S146-1 will be updated
---> Package openhab2.noarch 0:2.5.7~S163-1 will be an update
error: skipping package /var/cache/yum/x86_64/7/openHAB-Snapshots/packages/openhab2-2.5.7~S163-1.noarch.rpm with unverifiable signature
Have tried to disable pgp check, then I get this error:
Transaction check error:
Unknown error during transaction test in RPM
Something wrong with the latest package?
(edit: sorry wrong repo in original post, corrected)
Hi @bastiaan_van_h, is S164 doing the same thing? I’ve tested on Fedora 32, and this the signature check is passing, I don’t think there’s been any changes in the packages since S146.
Thanks @bastiaan_van_h, sorry for not checking that package specifically. I’m getting the same error for that specific package version.
There’s no difference between how S163 and S164 were created. The offline add-ons package for S163 (openhab2-addons-2.5.7~S163-1.noarch.rpm) has a valid signature even though this would have been created under the same settings and environment.
I’ll keep an eye on it and the build logs, but not sure if there’s anything that can be done at this point. Would you be able to post here if it happens to you again?
