chmre
(Ernst Müller)
#1
Does anyone know how to create canvas widgets?
uid: test_canvas_widget
tags: []
props:
parameters: []
parameterGroups: []
timestamp: Dec 23, 2022, 5:00:22 PM
component: f7-card
title: '=(props.item) ? "State of " + props.item : "Set props to test!"'
footer: =props.prop1
content: =items[props.item].displayState || items[props.item].state
slots:
default:
- component: oh-canvas-layout
screenWidth: 600
screenHeight: 400
imageUrl: /static/heating.jpg
slots:
default:
- component: oh-canvas-item
slots:
default:
- component: widget:schuko_card
hmerk
(Hans-Jörg Merk)
#2
What do you mean ?
AFAIK there is no canvas widget type, it’s the page config type.
chmre
(Ernst Müller)
#3
Thank you for your replay,
the above example is what I’ did using custom widget creation.
If this is not correct, what is the starting point
the other option is to create a new page, but what page is to be used or can be used?
there is no canvas page, so how do I’ start crating such a page?
I’ have checked the links attached, but cannot find oh-canvas-layout.
So may be I’ do not use the oh-canvas component for what they intended, but the documentation is not very informative on how to use them.
hmerk
(Hans-Jörg Merk)
#4
Create a new page by hitting the plus symbol, select create layout, select
Switch to fixed layout
Select
Fixed Canvas
and all added elements (widgets) will be oh-canvas components.
chmre
(Ernst Müller)
#5
Thanks,
I’ tried width the example found,
layoutType: fixed
fixedType: grid
label: Canvas Tutorial
sidebar: true
blocks: []
masonry: null
grid: []
canvas:
x: 10
y: 10
h: 800
w: 600
slots:
default:
- component: oh-clock-card
title: test
Q:
- there are some config elements, are they CSS elements or where are the defined?
- the widget is not displayed, what did I’ miss?
hmerk
(Hans-Jörg Merk)
#6
You are missing the canvas-layer component
layoutType: fixed
fixedType: canvas
blocks: []
masonry: null
grid: []
canvas:
- component: oh-canvas-layer
config: {}
slots:
default:
x: 20
y: 20
h: 150
w: 200
slots:
default:
title: Clock
footer: Testclock
chmre
(Ernst Müller)
#7
Thank you very much.
this is the way to getting started with canvas.
1th Create page
Select
Fixed Canvas
2nd Use oh-canvas.layer as the root element
layoutType: fixed
fixedType: canvas
blocks: []
masonry: null
grid: []
canvas:
config: {}
slots:
default:
x: 20
y: 20
h: 150
w: 200
slots:
default:
title: Clock
footer: Testclock
for my project I’ have one more question,
is it possible to have two widgets and connect the two widgets using a bezier curve?
However, thank you very much as this is a good staring point
hmerk
(Hans-Jörg Merk)
#8
No, that is not possibel AFAIK.
