Hi all,
I have some Shelly dimmer devices connected to my Openhab 2.5 using the MQTT binding.
On the other side I have the Homekit binding to control the devices with my Phone and Siri.
When activating a scene in Homekit, there goes something wrong with my dimmer value’s.
A dimmer should for example be set to 10% brightness but it goes to 100%, I can see this going wrong but do not know how to improve my transformation script to solve this. (I’m a beginner in Javascript)
This is what I see happening in the Log file.
2020-05-14 19:38:45.756 [ome.event.ItemCommandEvent] - Item 'ShellySpots' received command 10
2020-05-14 19:38:45.789 [ome.event.ItemCommandEvent] - Item 'ShellySpots' received command ON
2020-05-14 19:38:45.831 [nt.ItemStatePredictedEvent] - ShellySpots predicted to become 10
2020-05-14 19:38:45.867 [nt.ItemStatePredictedEvent] - ShellySpots predicted to become ON
2020-05-14 19:38:45.898 [vent.ItemStateChangedEvent] - ShellySpots changed from 0 to 10
2020-05-14 19:38:45.907 [vent.ItemStateChangedEvent] - ShellySpots changed from 10 to 100
2020-05-14 19:38:45.919 [vent.ItemStateChangedEvent] - ShellySpots changed from 100 to 10
2020-05-14 19:38:45.931 [vent.ItemStateChangedEvent] - ShellySpots changed from 10 to 100
First a dimmer value is sent, and then the ON command. The dimmer value is working correct. But after the dimmer value the ON command is sent, and interperted as a 100 value, resulting in my dimmers to go to 10% and right after that jump to 100% brightness.
The script I use to convert the Outgoing Value Transformation to a JSON for MQTT Looks like this:
(function(brightness) {
if (brightness > 0) {
var shellyobj = {"turn":"on", "brightness":brightness};
} else {
var shellyobj = {"turn":"off", "brightness":0 };
var data = JSON.stringify(shellyobj);
return data;
})(input)
This is correct for the dimmer value’s but the ON isn’t captured correct.
How can I fix this, so that for the ON command var shellyobj = {"turn":"on"}
(and for OFF var shellyobj = {"turn":"off"}
) is sent, without the brightness parameter?
