I am a beginner and i am trying to implement a rule where when the switch is activated, the value of a certain item gets carried to other item.
I implemented the following code
rule "Vacant mode_lab"
Item Vacant_lab received command
Lab_Tilt.sendCommand(SAT_north.state.toString)
What happens is when the switch is operated i.e., when Vacant_lab receives command ON, the rule works. However, values for SAT_north is being sent every second and those values are not updated in Lab_tilt. Please suggest a way to overcome this problem.
I think you have to do it the other way around. If i understand it right SAT_north is sending every second a value and this value should be transfered to Lab_tilt if the switch Vacant_lab goes to on. Right?
rule "Vacant Mode"
Sat_north received update // this happens every second
if (Vacant_lab.state == ON) then {
So if the switch is on every update will be transfered. I am not sure if the syntax ist correct.
