Cast problem Rain mm/h to float
Rain is defined like
Number:Speed        weather_current_rain                "Regen"
if I use following query
	if (weather_current_rain.state > 0.05 | "mm/h" )
it’s working like expected.
Due to the fact that a huge number of decimal places are shown in .state I would like to cast 0.01570000125600000 to 0.016 or 0.015 for output
I tried the following:
		var String Ausgabe = String::format("%.2f", (weather_current_rain.state as DecimalType).floatValue())
unfortunately I get following error:
 Could not cast 0.016000012800000 mm/h to org.eclipse.smarthome.core.library.types.DecimalType; line
If I use the same for temperature it’s working without problem. What is wrong?
Got it:
just change to:
		var String Ausgabe = String::format("%.2f", (weather_current_rain.state as QuantityType).floatValue())
it*s working.
