Hi all!
Can I track mqtt topic in rules ? For example: if in topic /aaa have message then do something (replace text item on received message) AndI need in .rules only, not in .items because I need change received message and then output on any item.
You can’t You need to use the mqtt binding with an item to received messages But you can do what I think you want
Have an item to receive the messages:
String MQTTreceivedMessage { mqtt="<[broker:topic:state:default]" }
Then in a rule:
rule "MQTT received" when Item MQTTReceivedMessage changed then val receivedString = MQTTReceivedMessage.state.toString // Do what you want end
Thx for info. I know this method, but want without use temp item. But I can make this item invisible… Ok, thx.
