grhosso
(Juan)
February 24, 2020, 8:44pm
1
Hello, I open this topic, because I have a few issues trying to visualize information from Radiator Thrmostat through CCU3 and Openhab.
I cannot see the variable CONTROL_MODE and BOOST_TIME properly. I see a strange String in the CONTROL_MODE and no information in BOOST_TIME.
This is my ITEM files, how I declarate the items:
Number Curr_T_1 "Current temperature [%.1f °C]" <temperature>
Number Targ_T_1 "Target temperature [%.1f °C]" <temperature>
Switch Low_Bat_1 "Battery [%s]" <energy>
Number Act_Prof_1 "Perfil Activo [MAP(modos.map):%s]" <settings>
String Mod_1 "Modo [%s]"
Switch Mode_Boost "Boost mode" <settings>
Number Boost_Countdown "Boost countdown" <settings>
And this is my SITEMAPS file:
Text item=Curr_T_1
Setpoint item=Targ_T_1 step=0.5 minValue=6 maxValue=30
Text item=Mod_1 label="Modo [%s]"
Switch item=Act_Prof_1 icon="calendar" mappings=[1="Tardes ON", 2="Tardes OFF", 3="Apagado"]
Text item=Low_Bat_1 label="Low battery? [MAP(modos.map):%s]" valuecolor=[Low_Bat_1==Uninitialized="lightgray", ==ON="red", ==OFF="green"]
Text item=Boost_countdown label="Minutos"
Switch item=Mode_Boost label="Boost"
There is something wrong in my setup?
thanks!
Hello @grhosso ,
what thermostat do you have? You can check in the paperui what type your item should use. e.g. for me:
Control Mode
homematic:HmIP-eTRV-2:xxxxx:yyyyy:1#CONTROL_MODE
Number:Dimensionless
Boost Time
homematic:HmIP-eTRV-2:xxxxx:yyyyy:1#BOOST_TIME
For mine these items work.
Number Thermostat_BoostTime "Thermostat Remaining Boost time [%d]" <clock> (fgTemperature) {channel="homematic:HmIP-eTRV-2:xxxxx:yyyyy:1#BOOST_TIME"
Number Thermostat_ControlMode "Thermostat ControlMode [%d]" {channel="homematic:HmIP-eTRV-2:xxxxx:yyyyy:1#CONTROL_MODE"```
grhosso
(Juan)
February 25, 2020, 7:47am
3
Hello @Schrott.Micha ,
I read before that CONTROL_MODE is a String, but I will try with Number, but I have realize that I made a mistake (copy paste) because I did not use the [%d], instead of, I used floating.
I will check it again, and I will let you know.
Thanks.
grhosso
(Juan)
February 25, 2020, 8:19am
4
I have same Items, I only miss the “Dimensionless” characteristic … (Number:Dimensionless )
When I switch from AUTO to MANUAL, the MODE return always 0.
BTW, I have the Standard Radiator Thermostat from Homematic, (with the wheel)
grhosso
(Juan)
February 25, 2020, 2:10pm
5
Well, I do not get any info in the channel. I have open a topic in Homematic forum, because I think is an issue from Homematic, and not from Openhab. When I switch the Mode, there is not info in the channel, no changes…
Great.
I always use the Paperui - to see what configuration is used for the channel, and what type the channel returns.
You can also check the XML-API - if you install the xml-api plugin .
